It is currently Tue Nov 10, 2026 21:25
PostPosted: Fri Jul 08, 2005 18:53
I've dug out this old Compaq video card and from what I can tell it uses an S3 ViRGE/GX chip [ 86C385 ]. It has an onboard 'Feature' [ VESA ] connector... but what I find odd is that there is a 79-pin connector [ at the top of the board ] with traces that come straight from the top-half of the chip, and a 79-pin port [ at the bottom of the board ] that connects with the right face of the chip.
This is really baffling... google didn't come up with anything.
Could this port eliminate an LVDS driver board? I read on a Dutch site that some LVDS LCDs could use the VESA port.
The card uses PCI and has 2MB VRAM. I'll try to do some ASCII art of it and post later.
PostPosted: Fri Jul 08, 2005 20:46
A pre-historic SLI setup 8O
PostPosted: Sat Jul 09, 2005 0:29
__
  |________________________________________________________________
                                                   Pins            |
 VGA                                                               |
                                         ___    ___                |
  |                      ________       |   |  |   |  << VRAM      |
  |                     |        |      |___|  |___|               |
  |                     |  GPU   |                                 |
  |       ^^^           |        |                    Socket       |
  |   s'more stuff      |________|         ....................    |
  |_______     _                          _     ___________________|
PostPosted: Tue Jul 12, 2005 5:31
Anyone at least have a spec sheet for this GPU?
PostPosted: Sun Sep 04, 2005 2:01
Dude, that's socket & pins for an Memory expansion module for example 2 Megabytes of extra RAM. Matrox and some older ATI cards are made the same way, you cannot use these connectors for anything other than RAM expansion, sorry.
Regards, Per.
PostPosted: Mon Sep 05, 2005 20:38
Thanks, mate.
Good to know.
