It is currently Tue Nov 10, 2026 20:19
PostPosted: Mon Oct 25, 2004 8:27
I have looked around alot on this site for information on hooking up a Nokia 3310 LCD.
I found a couple of configurations:
* Zener diodes and resistors
* Direct wirering
* Using 7445 with 3.3 v circuit.
My tests have been done on a laptop.
Measuring the voltage on my LPT port, Pin7 to Pin25, it sais 5V
Connection the Zener diodes I measure 1.8 volts
Direct wirering gives 3.4v on pin 7 and 4.7v on data pins
I have not tested 7445 with 3.3 circuit.
I still have not got any test-picture on either of the couplings.
Any suggestions on what could be wrong?
For example, should I use the direct wirering for the power supply but zeners for data pins?
/Best regards
Michael
PostPosted: Sat Aug 20, 2005 4:34
This would be great as it would help me set up my 3210 which should be very similar! is direct wiring or with diodes better?
PostPosted: Mon Aug 22, 2005 1:22
I wrote something for u some time ago but it's in ...Greek. It's here http://www.hlektronika.gr/phpBB2/kat_lcd3.php
The guide uses the zener circuit.
You should understand the basics because of the many pictures, or use a translation page to translate from Greek to English.
If anything else fails, ask me!
gsmaster :)
PostPosted: Mon Aug 29, 2005 15:31
i used the same components on the board
it works fine
now i`m changing some of the screenfile`s to fit a 3310 display.
i have an analog clock, a digital clock, Camel and a bug
(1 made them work on a 84X48
PostPosted: Sun Sep 04, 2005 0:29
Will it burn the 3310 LCD if i directly connect control lines to TTL level interface? I looked in datasheet, it says that absolute maximum rating for control lines is Vdd + 0.3V = 3.3-3.6V. Will LCD tolerate 5V?
PostPosted: Sun Sep 04, 2005 8:59
mine are hooked directly here no burnt lcd BUT
this is with a nokia 5110 LCD im not sure if they are different
Users browsing this forum: No registered users and 46 guests
