It is currently Wed Nov 11, 2026 21:09
PostPosted: Sun Aug 28, 2005 22:27
PC0802B-YNRD-O is all i see on it,it's a 8 x 2 display that's all i know really, 14 pin connection and it apear's to have a controller built in,any 1 have a idea how to get it working??
PostPosted: Sun Aug 28, 2005 23:21
Since it's a character module there's a great chance that it's HD44780 compatible.
PostPosted: Mon Aug 29, 2005 16:46
Yes i figured it would be,im having a heck of a time getting any info on it though.
PostPosted: Mon Aug 29, 2005 18:52
With a multimeter you could trace if the +5V and GND lines go as with typical HD44780 connection and if that's the case just build the same cable. I didn't check anything with one of my Epson panels but thankfully it worked with the same cable without blowing anything up. :)
PostPosted: Mon Aug 29, 2005 21:55
where is the data sheet on the controller? ill try it and se what i come up with :)
PostPosted: Mon Aug 29, 2005 23:43
http://www.doc.ic.ac.uk/~ih/doc/lcd/interfac.html
http://home.iae.nl/users/pouweha/lcd/zips/hd44780.zip
PostPosted: Wed Aug 31, 2005 2:17
Thank's ill giver her a shot tonight :)
PostPosted: Wed Aug 31, 2005 2:55
http://www.icehw.net/article.php?id=99 the pin gide there would be the same right?
PostPosted: Wed Aug 31, 2005 9:06
Yes that's basicly the same connection. Either use pot to control contrast in pin 3 or just wire it to ground as it should usually work like that just fine.
PostPosted: Fri Sep 02, 2005 0:52
It live's! now i have to make a new post..i got a lcd that's killing me...Thank's Zee u own!
Users browsing this forum: No registered users and 55 guests
