It is currently Wed Sep 30, 2026 8:19
PostPosted: Tue Sep 27, 2005 1:55
Hello everybody - I'm new to LCDs and need a little help indetifying a connector from the cell phone to the display. I'm attaching a few pics. What I'm looking for is something to extend the connection so I can do some testing on the controller. This is from a Nokia 918+. There's not a lot of information (schematic or datasheet) for this product on the web.
Thanks for any help you can give.
Sark
PostPosted: Wed Sep 28, 2005 3:51
Not an exact match, but these guys have made some boards for cell phone lcds with a similar connector. They might be able to tell you where they get them or a part number to get you pointed in the right direction:
http://www.shop-en.display3000.com/pd1960842619.htm?categoryId=2
Hope this helps a little. :D
 Post subject: Thanks
PostPosted: Thu Sep 29, 2005 13:09
Thanks One~Zero, you rock!. How did you find that so easily? I've been looking for three days; closest I got was a place in Germany.... Do you know what this part is called?
Thanks again.
SARK
PostPosted: Thu Sep 29, 2005 15:36
The only reason I knew is because I had bought a couple of those displays with the boards off these guys from Ebay about a month or so ago. I'm not sure what type of connector this is, as I've never seen it before until I got those displays. You could try looking at Digikey or Mouser under SMD/SMT connectors or something. I'll see if I can find something more a little later.
 Post subject: Found it...
PostPosted: Thu Sep 29, 2005 22:58
.. I think. It seems to be a Hirose DF23. Now I need to assemble a connection for a flat cable.
Thanks again.
PostPosted: Fri Sep 30, 2005 2:54
Your best bet is to try something like the link I listed earlier. If you can get the mating connector, just make a breadboard adapter with that connector on one side (to plug the lcd into) and something like a 16-pin straight header on the opposite side. It would be a lot easier to play with that way I think.
Users browsing this forum: No registered users and 121 guests
