It is currently Sat Sep 26, 2026 12:41
PostPosted: Fri May 13, 2005 19:58
Datavision 160x160 Dot Matrix LCD DG-16160-11-S1FTLY
it's a sed1335f controller that I just can not to seem to get to work at all. The best I get is flickering black lines up and down the display when using hypelcd or LCD studio. I've tried several wiring schemes and nothing seems to work for me. Any help would be appreciated
Here is a link to the data sheet
http://personal.nbnet.nb.ca/dunnbarr//DG-16160-11-S1FTLY.PDF
PostPosted: Sat May 14, 2005 13:03
Can you post how you have yours connected? That would help quite a bit. :D
PostPosted: Sat May 14, 2005 23:17
j1
LCD --- PP
1------- 1
2-------17
3-------14
4-------16
5------ +5 ( 10k resistor)
6-13 == 2-10 data pins
J2
LCD
1-------Ground
2------ +5v
3--------- negitive voltage (-12)
4--------whipper on pot other end of the pot goes to ground
5------- +5
6and7 LED power and ground
PostPosted: Sun May 15, 2005 1:12
For data pins, I'm sure you just meant (lcd)6-13 to (PP)2-9...no connection on pin 10. For you J2 connection pin 1 (ground), what do you have that going to on the PP? Pins 18-25 should be grounded on the PP, and tied to pin 1 on J2.
On your contrast adjust, what do you have the other sides of the pot tied to? They should be VCC(pin2) and VLCD(pin3). Does your LCD have an onboard negative voltage generator? Or did you already have a circuit to generate the -12vdc?
Check all that first.
PostPosted: Sun May 15, 2005 1:13
Wiring looks correct, Make sure it's good, use a multimeter to check the connections. Can you adjust contrast?
Also i assume that you have configured LCDHype / LCDstudio to match your wiring scheme.
PostPosted: Sun May 15, 2005 3:19
I think I am going to put this display aside for now, but would like advice on whitch of these two displays would be the simplest to connect?
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... %3AIT&rd=1
or
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 7511835034
PostPosted: Sun May 15, 2005 4:00
All of them will pretty much require the same amount of time and effort to connect. Don't give up so easily on your DataVision :D
You'd still have to check everything just mentioned previously, regardless of what kind of LCD you have or plan on getting. Think of it this way, yours already has a controller built in....a lot of them don't.
PostPosted: Sun May 15, 2005 4:02
Truthfully I think I have borked the display, I don't even get the blacklines anymore.
Edit, I got the test on the sed 1335 driver on lcd studio to output a black screen on the LCD but I still can't get data outputed to the screen.
PostPosted: Sun May 15, 2005 10:42
Indeed don't give up on it. As it appears that you get unpredictable results when hooking it up i do suspect some wiring error, relax and re-wire the lot !
Can you adjust the contrast or not?
Black lines across the screens are typical SED1335 symptoms, doesn't mean it's borked.
edit: those 2 ebay LCD's are nice but quite expensive IMHO
PostPosted: Sun May 15, 2005 17:42
I can't adjust the contrast at all it seems. I will take it apart and rewire it compleatly and let you know if it helps or not.
any hints on where to get LCD's like those on ebay but less expensive?
PostPosted: Thu Jun 16, 2005 19:44
Abby_Normal...
O.k., I went and bought some of these displays off of Ebay ($10/ea with a controller on board is a pretty good price :D )
I hooked mine up like yours, didn't even bother with LPT 18-25, with my VLC voltage of -20vdc (you stated -12 in yours...don't think that's enough) with the contrast adjustment going to VLC, center to Contrast and other side of pot to VDD (+5vdc). I used maxim's MAX637 for the negative voltage generation and followed their example right on page 1 of the datasheet. You could request free samples of this IC from them (make sure you request the MAX637 which gives you -15v).
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1381
Here are some pics...
lights on
lights off
Here is the negative voltage power supply breadboarded together
Hope this helps a little.
PostPosted: Tue Jun 28, 2005 20:55
Abby_Normal, were you able to try this out?
PostPosted: Thu Jun 30, 2005 16:52
Not yet, still waiting for the chip to arrive
PostPosted: Sun Oct 30, 2005 4:09
Hi everybody. I'm new to this message board. I recently bought a graphics LCD controller off of ebay with the sed1335 controller on board. It seems to be the exact same one mentioned in this list. I was able to get the contrast working and the backlight works well. That is the extent of the success I had.
Mainly, I'm unsure on how to initiallize and write data to it. I am having trouble understanding how to calculate the TC/R value for the init sequence. If anyone has some working code, perhaps just a Hello World program, could you please post it here. Thanks a bunch in advance.
Matthew
PostPosted: Sun Oct 30, 2005 4:48
Why bother writing the code when Henri has done such a wonderful job with LCDinfo :D
If you really are looking to write your own stuff, you may want to start here instead:
http://forum.lcdinfo.com/viewforum.php?f=9
Users browsing this forum: No registered users and 54 guests
