It is currently Wed Nov 11, 2026 22:39
PostPosted: Tue Oct 25, 2005 9:37
This is what I've managed to trace from an onboard EL-inverter circuitry.
The problem is that the transformer (T) was broken (only the legs were in place) and the device itself has been a measuring equipment of some sort, not much bigger than a typical remote controller so there has not been much space for the transformer. The device itself was running from a 9V battery.
Could anyone suggest what kind of a replacement transformer I should be looking for it?
PostPosted: Tue Oct 25, 2005 15:43
Can't help you with that, but i do know you can buy cheap mini-inverters similar to that thing to drive EL-sheet.
They are little squared black boxes with 4 pins.
PostPosted: Tue Oct 25, 2005 16:51
But it would mean extra parts hanging from the display with everything else already built-in.
PostPosted: Mon Oct 31, 2005 7:38
any model number written on the inverter ic?
PostPosted: Mon Oct 31, 2005 7:56
There's no IC. The inverter-parts are with the rest of the control electronics.
Users browsing this forum: No registered users and 42 guests
