It is currently Thu Nov 12, 2026 22:53
 Post subject: LM213xb
PostPosted: Sat Nov 05, 2005 21:36
hi
http://forum.lcdinfo.com/viewtopic.php?t=659
Is it enough to a LM213xb display (negative voltage)
thanks
PostPosted: Sun Nov 06, 2005 1:13
You'll need at least -10 V, my crkt is is only give you -12 at no load and not more than -3-4 at 2mA load.
Csaba
 Post subject: Re: LM213xb
PostPosted: Sun Nov 06, 2005 3:52
matrix0110 wrote:
hi
thanks
What's the negative voltage requirement for your LCD? There are plenty of simple circuits for this type of thing, but helps to know what your requirements are. Post a data sheet if you have one.
PostPosted: Sun Nov 06, 2005 8:35
hi
-10,5 V and (I think) 2mA (VEE) 35mA (IDD)
I see a voltage inverter with max767 or something like that, but I can't find :-( (it gives more (-12) from +5V)
sorry for the mistakes
thanks
PostPosted: Sun Nov 06, 2005 8:37
here is the datasheet:
http://www.datasheetarchive.com/search. ... sType=part
PostPosted: Thu Nov 10, 2005 18:14
is it enough or not??
I see a schematic with max767 but now I cant find, can somebody show me?
PostPosted: Thu Nov 10, 2005 18:56
Look at the datasheet for the MAX635-637
http://pdfserv.maxim-ic.com/en/ds/MAX635-MAX637.pdf
On page 5 there is a circuit for a -10vdc out.
PostPosted: Fri Nov 11, 2005 15:03
thanks
