It is currently Wed Oct 07, 2026 21:02
PostPosted: Thu Mar 09, 2006 13:53
Good day!
I am needing the date sheet of the graphical display
Data vision LCD 12864-12 s1fbly,
already I looked for in some sites and in google but I did not get success.
thanks!!
Marcelo
PostPosted: Thu Mar 09, 2006 21:28
Try....
http://www.datavision.com.tw/english/table/dgtable/dg12864-12.htm
or....
http://www.dst-gmbh.de/dvkat/dg12864-12.htm
PostPosted: Fri Mar 10, 2006 13:25
Ok, thanks a lot!!
What is the frame ground pin? What is you function?
thanks!
Marcelo
PostPosted: Fri Mar 10, 2006 21:49
It's connected to the metal frame which surrounds the display. It's used to provide a ground path for any static electricity.
PostPosted: Sat Mar 11, 2006 14:44
Yes FRAME-GND can be connected to GND.
PostPosted: Sat May 06, 2006 3:02
Hi guys! I just got this LCD, and I need some more info on it... I've done a little with electronics before but not much. How should I actually interface this thing? Is it better to go serial or parallel? Any help is greatly appreciated!!!
Warren
PostPosted: Sat May 06, 2006 22:48
This particular model is a T6963C controlled 128x64, so grab yourself the the T6963C to LPT wiring scheme.
Most 128x64 displays are KS0108 controlled so make sure yours is exact the one mentioned above.
PostPosted: Sun May 07, 2006 0:06
Yes it is that exact lcd.Do you have a link for the schematic?
PostPosted: Sun May 07, 2006 7:06
This is a very commonly used T6963C to LPT scheme
http://liquid-mp3.schijf.org/schematics ... -24128.gif
Users browsing this forum: No registered users and 258 guests
