It is currently Thu May 14, 2026 10:05
PostPosted: Sun Mar 19, 2006 22:33
I have a LCD display 240x128 from Dalian which I try to connect to a computer through the paralell port. The display uses the 6963c controller.
I'm halfway there but just got garbage when I try the "LCD Test" button in PowerLCD 1.1. Can't seem to figure out what's wrong.
I've used this wiring: http://www.sportsbil.net/lcd/DV_t6963c.gif
You can also see some pictures of what I get here (datasheet is there too): http://www.sportsbil.net/lcd/. Different garbage every time I push the "LCD Test" button.
Any comments will be greatly appreciated.
Regards,
PostPosted: Mon Mar 20, 2006 0:13
First make sure your wiring is ok, by rechecking with a multimeter.
The check whether your wiring scheme is supported by PowerLCD or try LCDinfo / LCDstudio / LiQuidMP3 in which you can set custom pin layouts.
edit: looks like wrong wiring too me
PostPosted: Mon Mar 20, 2006 10:30
My problem is that I don't know if the wiring is OK - or if the one I've used can work. So I don't have the knowledge to actually do the checking.
I will try LCDinfo though, thanks for that.
If you can say anything of what you think is wrong with the wiring, that would be great.
Regards,
PostPosted: Mon Mar 20, 2006 13:09
Well judging by that picture of your LCD it just looks wrong!
The wiring scheme you used is a good one, however i have no idea how PowerLCD works and if it requires a special wiring scheme, hence i said try other LCD apps which have an option to configure the wiring.
Can you adjust the contrast?
Users browsing this forum: No registered users and 53 guests
