It is currently Tue May 26, 2020 11:57
 Post subject: IEE 03601-90 VFD
PostPosted: Thu Jan 13, 2005 1:39
Here's a driver for the IEE 03601-90 4x20 character VFD:
http://www.skippari.net/lcd/alpha/plugi ... driver.dll
Connection used was very simple.
LPT - VFD
1 - WR
2-9 - D0-D7
 Post subject: 2 x 40 VFD
PostPosted: Tue Feb 28, 2006 18:22
Hi Henri
Can you make a plugin for:
IEE S03601-96-080 2x40 character VFD ?
If you can send me the source code too :oops:
Best Regards!
PostPosted: Tue Feb 28, 2006 18:23
DataSheet http://www.vfdworld.com/techdocs/IEE_03601-96_2x40_VFD.pdf
PostPosted: Fri Mar 17, 2006 19:42
I also have this vfd , but cannot get it to work in lcdinfo.
that DLL plugin is for your program henri? , or something else.
i am not seeing the link to it and lcdinfo program?
PostPosted: Fri Mar 17, 2006 19:57
Hi...
The only thing that I have to work with this VFD is a self made visual basic program... only a few informations and I don´t know if my software logical is correct... and the program from vfdworld.com
I think that only Henri can help us... :D
PostPosted: Mon Mar 20, 2006 15:57
that IEE vfd on VFDworld.com, has the same command structure
accordind to the PDF files for each the only differance i see is one is a 2x40 and the one I have is a 4 x 20 seems like verly little should have to change to make it work.
PostPosted: Sat Mar 25, 2006 15:17
I really need to catch up with this stuff.
What I remember looking into few different IEEE VFD datasheets they had similar commands. I suspect that the driver itself was programmed to support different sizes, could have been just that I was lazy and didn't add it to the configuration dialog.
Can you get any output with your displays using this driver ?
Yes it's for LCDInfo. http://forum.lcdinfo.com/viewtopic.php?t=387
Rafael_Brazil wrote:
Hi Henri
Best Regards!
Just email me and I'm sure we can come up with a solution.
PostPosted: Sat Apr 01, 2006 3:36
I had already sent an email for you... :oops:
PostPosted: Mon Apr 03, 2006 21:38
thanks Henri
I will download the new files and give that a shot.
PostPosted: Mon Apr 03, 2006 22:02
Hi jpace113,
Can you convert the source code to S03601-96?
Thanks!
PostPosted: Tue Aug 22, 2006 15:52
No news? I still can´t get work with lcdinfo... :(
PostPosted: Mon Sep 11, 2006 2:08
jpace113,
I have this VFD working just fine using the VFD thinger VB app from the vfdworld.com web site.
I also have the PDF spec sheet of this IEE 03601-96 display
http://www.gokrystal.com/pix/VFD_IEE_03601-96_2x40.pdf
Hope this helps you figure out your problems.
~Boyan
