It is currently Wed Sep 16, 2026 15:43
PostPosted: Wed Jan 29, 2003 4:27
i don't know if you know me.
I programmed for about one year a program like lcdinfo, named PollinLCD.
I stopped my project, because I had no time.
Now i restarted my project, and I found your page.
I loked around and then I noticed, that some parts (e.g. your config-file) looks like mine.
Is it right?
Its no problem for me because my project was opensource.
My actual project is like yours:
Support for T6963C an other controllers
different displaysizes
dataplugins so you can show any kind of information
If u are interested in the code for the driver and pluginsystem - let me know. :)
mfg
Maik Rutsche
PostPosted: Wed Jan 29, 2003 4:33
This post is to notify me, if someone replies.
PostPosted: Wed Jan 29, 2003 11:42
Yep, I know who you are. Or should I say that I've seen your source. ;)
I'm glad that you had your source available as I got many ideas from it (got my first lcd in april last year and lcdinfo is basically my first windows program). I don't remember anything else than the bitmap loading function that I would have used but there may be more.
But you can see your source's influence in some of the function names in my source. ;)
First version+source: http://www.skippari.net/lcd/lcd_info_v0.1.zip
How it evolved: http://www.skippari.net/lcd/lcdinfo_old.html
And the latest source I found at this site: http://www.skippari.net/lcd/lcd_info_v0.3_source.zip
You can also get the latest development source - just let me know if you are interested.
Of course I'm interested in the driver and plugin system code. :)
I've been thinking of a data plugin support to LCDInfo too and it would be nice to see how someone else has done it.
PostPosted: Wed Jan 29, 2003 12:47
Here is a small program I use to test my dataplugins:
http://rogue.wh20.tu-dresden.de/~maik/glcds/eigenes/mlcdp/PluginTest.zip
The var_winamp-plugin only works if this http://rogue.wh20.tu-dresden.de/~maik/glcds/eigenes/mlcdp/TreiberTest.zip is installed and started in winamp2.x.
(Analyzers are not yet implemented, its still a testversion with no graphic-variables)
The mbm5-plugin works with mbm5 version 5.2.1.0 and I think newer versions.
Variables provided by the performance-plugin are defined in the "var_perf.ini".
Perhaps we could work together?
PostPosted: Wed Jan 29, 2003 17:40
I tried the plugin test and everything seemed to work fine except the performance counter plugin as it didn't find a vlcPerfUtils6.bpl file.
Also I don't have a T6963C display using the Pollin wiring (i guess that's what you're using) at hand right now so I only was able to use the virtual lcd in the driver test but I can test this later.
I think working together would be a good idea. :D
PostPosted: Wed Jan 29, 2003 18:25
Yes its a problem of the performance counter.
It needs some runtimelibraries.
You have a different wirring?
All paramters are seperate adjustable.
If you give me a schematic of your wiring then a could make a new option in the driver.
PostPosted: Wed Jan 29, 2003 19:09
Yes, I have a display with the powerlcd wiring to test wiring settings in the new LCDInfo version. In that you can define yourself how you have the pins connected.
But I also have a 240x64 display with the pollin wiring so I should be able to test your drivers soon.
/* pollin*/
int wr=1;
int rd=17;
int cd=16;
int ce=14;
/* powerlcd*/
int wr=16;
int rd=14;
int cd=17;
int ce=1;
If you email me I can give you the latest LCDInfo development version + source.
PostPosted: Wed Jan 29, 2003 21:29
So here is the new Version:
Driver-Testprogram:
http://www.wh19.tu-dresden.de/~maik/glc ... erTest.zip
Look at the T6963C.ini and you will find 4 new options:
Pin_WR=1
Pin_CE=14
Pin_CD=16
Pin_RD=17
And here are the runtime libraries u need for the performance plugin:
http://www.wh19.tu-dresden.de/~maik/glc ... meLibs.zip
PostPosted: Thu Jan 30, 2003 10:39
I put the driver discussion to the other thread you started for it: http://www.skippari.net/phpBB2/viewtopic.php?t=113
Users browsing this forum: No registered users and 521 guests
