It is currently Thu Oct 29, 2026 9:07
 Post subject: DoubleBuffer
PostPosted: Mon May 29, 2006 17:23
Hello
I develop a drivers for t6963c controllers. I try to develop a doublebuffer.
However i don't understand this specification.
I tested by writing in RAM an image :
example :
#define frontbuffer 0x0000
#define backbuffer 0x0850
and used that to display
void InitBuffer(int buffer)
   if(buffer==0)
      G_BASE=0x0000;
      /* SET GRAPHICS HOME ADDR */
      WriteData(G_BASE & 0xFF);  // Data1: LowAddress graphic home addr
      WriteData(G_BASE >> 8);    // Data2: HighAddress
      WriteCtrl(SET_GRAPHICS_HOME_ADDR);           // Command: 0x42 -> 01000010
   if(buffer==1)
      G_BASE=0x0850;
i think it is false...
someone , use doublebuffer for t6963c?
PostPosted: Mon May 29, 2006 18:34
You're meant to use it so that you:
1) Clear the backbuffer and call InitBuffer(1).
2) You clear the frontbuffer and do your stuff into it, and when you're done you call InitBuffer(0) to set the frontbuffer visible on the screen.
3) You clear the backbuffer, do your stuff into that, and when done you call InitBuffer(1) to set that visible on the screen.
4) Loop back to position #2.
This is to get rid off of all the visible effects of drawing in the screen.
