It is currently Tue Nov 10, 2026 1:48
 Post subject: BA63 under DOS
PostPosted: Tue Dec 12, 2006 17:23
I'm trying to get a Wincor Nixdorf Display (BA63) running under DOS.
Windows, I've no problem with Hyper Terminal.
Dos - a different story. Does anyone have any experience with this?
I've attached 12v to pin nr. 1 on the 9 pin plug with the earth on pin nr. 5.
Pins 7 & 8 are bridged. This only leaves (I think) two more pins, pin 2 and pin 3. RTS & DTS (again, not sure).
Would appreciate any help on this.
Bill
PostPosted: Wed Dec 13, 2006 11:29
Silly me. Of course the pins 2 & 3 should be RXD and TXD
Have been fighting with this now for more than a week.
Bill
PostPosted: Wed Dec 13, 2006 20:46
What version of windows are you using?
Reason I ask is because newer versions don't natively support DOS, so you may need to enable your com port inside the dos window. Not sure what communications settings you are using, but you would set it like this:
For example, to set Com Port 1 to 9600 baud, Even parity, 7 bits, stop bits 1, at the command prompt, type:
com1:9600,E,7,1
To see a list of the modes for the serial port, just type:
mode/?
PostPosted: Thu Dec 28, 2006 13:49
Thanks for the reply, however, I don't want to use windows.
I want to keep this strictly as a dos machine.
I already tried the mode command in dos, with no luck.
GovanX
www.gsv-service.de
