It is currently Sat Sep 19, 2026 3:37
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: lcd optrex mdk 52 v
PostPosted: Mon Oct 10, 2005 21:12
hi people...
i have this lcd i take it out from a printer (a kyocera) and now i want make a lcd for my pc... but i dont understand nothing of this :?
thanks
PostPosted: Wed Oct 12, 2005 22:52
nobody helps me? 8O
PostPosted: Thu Oct 13, 2005 9:26
this is a guess, but maybe its hd74480 compatible, if so just try wiring it normal way, whats the worst that can happen ^^
http://lcdsmartie.sourceforge.net/circuits.htm
and the robot lord said "01001111010011010100011100100000010110010100111101010101001000000010000001010010
010001010100000101000100001000000101010001001000010010010101001100111111 2" - Bender
PostPosted: Thu Oct 13, 2005 10:04
Unlikely as it has no LCD controller onboard, so basically useless. Find some cheap one with HD44780 controller, that'll work for sure.
PostPosted: Thu Oct 13, 2005 20:44
arnt those 3 chips controllers? :P
PostPosted: Fri Oct 14, 2005 3:55
Column and row drivers.
PostPosted: Wed Jan 03, 2007 10:07
Pin
1 DB0
2 DB1
3 DB2
4 DB3
5 DB4
6 DB5
7 DB6
8 DB7
9 CS1 (left controller)
10 CS2 (right controller)
11 R/W
12 EN
13 D/I
14 Reset
15 Vpp (+5V)
16 GND
17 Vee (-5V to 0V)
18 Led A
19 Led K
You can only use the 8bit mode! (look at Datasheet "HD44102CH")
PostPosted: Wed Jan 03, 2007 10:57
Thanks for your reply. I have still some questions to make you, the pins of the lcd the numbers are equivalent where order of the right for the left or the left for the right? how I bind this? to the printer handle? what programs use?
PostPosted: Wed Jan 03, 2007 19:08
Look at the first Picture, Pin 1 is on the rightside (where the little 1 is).
I don't know to conect to the Lpt, ich dosen't use it with PC.
PostPosted: Wed Jan 03, 2007 19:16
is impossible to make it work in one PC? i want to display temperatures and info's of my pc... thanks por your reply
PostPosted: Wed Jan 03, 2007 20:12
It's not impossible. but you can't use the 4Bit-mode, so you need a interface circuit.
The easiest way is to use somethig like LCDprog and an cheap HD74480.
PostPosted: Wed Jan 03, 2007 23:14
hum... so this LCD cant work with my lpt port because he is one 8 bits... right.. so the easiest way is buy one with the HD74480... so is impossible make it work... :(
PostPosted: Thu Jan 04, 2007 2:08
Why is it impossible to use it at 8 bit through the parallel port?
You can connect only one display of those kind but it is possible.
Concerning the HD44780, I'm currently using a 8x2 HD44780 set at 8 bit through the parallel port.
And more...I'm going to use the parallel port to drive 3 LCD HD44780 at 8 bit !
Regards,
Bob
PostPosted: Thu Jan 04, 2007 2:48
How do you conect 8 Datalines and the 6 controllines to the LPT?
PostPosted: Thu Jan 04, 2007 20:29
The parallel port gives you 12 pins to drive a LCD display: 8 for data lines, 4 for control pins.
DB0-DB7 ---> parallel port data lines (2 to 9 of the parallel port)
CS1,CS2 ---> pin 1,14 of the parallel port
EN ---> pin 16 of the parallel port
R/W ---> to GND (you can only send data but not read from the display)
D/I ---> pin 17 of the parallel port
Reset ---> can be driven individually by a button
Remarks: pin 1,14,17 are active low, pin 16 is active high.
The pin D/I actually I don't know what is its function but if it's a control pin for the display can be driven by the parallel port.
Regards,
Bob
Users browsing this forum: No registered users and 196 guests
