It is currently Tue Nov 10, 2026 2:40
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 04, 2007 21:25
I don't remember, that the LPT has so many controlpins. I preffer RS232 ;-)
The D/I Pin is equal to the R/S signal on HD44780, and all signals are high active on this device.
PostPosted: Thu Jan 04, 2007 23:37
Well...the serial port is easier to manage from the software "side" but you always need an extra circuit to drive a device through it.
With the parallel port you can drive a LCD directly.
It's a matter of tastes I think :wink:
Regards,
Bob
PostPosted: Fri Jan 05, 2007 0:36
washburn_it wrote:
The parallel port gives you 12 pins to drive a LCD display: 8 for data lines, 4 for control pins.
DB0-DB7 ---> parallel port data lines (2 to 9 of the parallel port)
CS1,CS2 ---> pin 1,14 of the parallel port
EN ---> pin 16 of the parallel port
R/W ---> to GND (you can only send data but not read from the display)
D/I ---> pin 17 of the parallel port
Reset ---> can be driven individually by a button
Remarks: pin 1,14,17 are active low, pin 16 is active high.
The pin D/I actually I don't know what is its function but if it's a control pin for the display can be driven by the parallel port.
Regards,
Bob
thanks for the reply guys can i put the lcd work in this way or te chip that i have is impossible to connect? i'm confused :oops: my english is bad :lol: i'm from portugal :)
regards
JMV
PostPosted: Fri Jan 05, 2007 2:14
Regards,
Bob
That's right. I work with Microcontrollers so its easy for me :-)
YES, you can use it with a PC. But i think you will need a softwaredriver.
PostPosted: Fri Jan 05, 2007 11:24
is any program that supports this lcd...? or where can i find the driver to use it? :) i am noob with lcd's :lol:
jmv
