It is currently Mon Nov 09, 2026 18:30
PostPosted: Tue Feb 06, 2007 3:47
Hi..
I have a bunch of these displays.
Are they supported in LCDInfo?
The controller is a FIPC8367 parallell/serial controller.
I have wired it according to my best knowledge, but i only get a underline curson flashing wildly around the display.
Here is how i wired it
parallel Port: Display (NEC):
Pin: Name: Name: Pin:
1 /STROBE -------------- /WR 1
2 D0 -------------- D0 15
3 D1 -------------- D1 13
4 D2 -------------- D2 11
5 D3 -------------- D3 9
6 D4 -------------- D4 7
7 D5 -------------- D5 5
8 D6 -------------- D6 3
9 D7 -------------- D7 1
10 /ACK --o
11 BUSY --o------BUSY 27
16 ---------------- /CS 23
18 - 25 GND ------------o-- GND 2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34
Does this sound somewhat right?
Here is datasheet for the displays.
http://www.qscomp.cz/Pdf/CU20026SCPB-T30A-01.pdf
PostPosted: Sat Feb 10, 2007 2:06
The closest existing driver is probably the CU20045SCPB-T23A driver. You should get the CU20045SCPB-T23A datasheet and compare the commands to see if they match.
