It is currently Sat Sep 19, 2026 23:54
PostPosted: Fri Feb 14, 2003 21:16
Hi
The new versiond doesnt work with 128x128 Displays with t6963c controller can u fix it please :D
PostPosted: Fri Feb 14, 2003 23:26
hmm, can you specify that 'new version' you're talking about a bit more specifically? i'm running 0.3.2 and some of the pre 0.4.nn versions, and they all run fine with my 128x128 t6963c display :D
PostPosted: Sat Feb 15, 2003 11:46
Knowing what the "new version" is would definately help and also what kind problems you are having ?
PostPosted: Sun Feb 16, 2003 3:07
I mean 0.3.2.
The Display doesnt show anything.
In version 0.3.1. is everything fine
PostPosted: Sun Feb 16, 2003 12:43
Was the 0.3.1 downloaded here or is it the Ayreon's version ? Do you have the wiring setup correctly in the configuration ? If you used the Ayreon's wiring diagram you need to use the tweakers.net/powerlcd wiring.
Users browsing this forum: No registered users and 52 guests
