It is currently Tue Sep 22, 2026 14:40
 Post subject: Lcd ampire 320x240
PostPosted: Mon Mar 24, 2008 23:34
Hi all,
i have Ampire AG-320240A, and i need help for link with my pc...
the datasheet is here http://www.gamma.pl/technical/ampire/ag/AG-320240A.PDF
pin lcd:
1 D0
2 D1
3 D2
4 D3
5 /DISPOFF
6 FLM
7 M
8 LP
9 CP
10 VDD
11 VSS
12 VEE
13 VO
14 FGND
this lcd need controller and other??? or not...
the USB13700 work for this??
thanks for help
PostPosted: Tue Mar 25, 2008 12:22
Yes that is a controllerless lcd so you need a controller to drive it.
Looks good to go with the USB13700.
PostPosted: Tue Mar 25, 2008 18:02
thanks henri
i send private message for you :D
PostPosted: Mon Apr 07, 2008 9:47
How to connect a LCD module directly to pc,
Normally, I know it's for MCU or Controller.
PostPosted: Mon Apr 07, 2008 13:59
You can connect some modules to the parallel port. But parallel port connection might sometimes be unreliable and it's not very suitable for larger graphics displays. These days better alternative can be USB. But for that you need additional hardware. One example is the USB13700 controller: http://forum.lcdinfo.com/viewtopic.php?t=2358
PostPosted: Tue Apr 08, 2008 5:43
That's a very good suggestion,
Good device. :P
Users browsing this forum: No registered users and 220 guests
