It is currently Tue Aug 25, 2026 21:36
PostPosted: Sun Mar 02, 2008 23:31
Thanks to henri,
it now works and looks fine. :)
PostPosted: Sat Mar 08, 2008 16:12
Glad to see the display working :)
PostPosted: Wed Mar 12, 2008 23:01
Dear Henri,
ever thought about 2 grafix-pages to get 50%halftone-display? I know this from the old SED1335s where you blend 2 layers via some XOR to get 50%. Would be a cool thing. I already tried to handle something like this with gif-animations, but did not worked "cool". :D
PostPosted: Thu Mar 13, 2008 15:32
S1D13700 actually has better grayscale support than S1D13305. It supports both 4-bit (16 levels) and 2-bit (4 levels) grayscale modes. The limiting factor becomes from the amount of the framebuffer RAM which the S1D13700 has 32KB.
I have been playing with 2-bit grayscale with a 320x240 display. This needs 19200 bytes of RAM. 4-bit grayscale with this resolution would need more than the available 32KB.
640x200 display at 2 bpp would need 32000 bytes so I guess it should fit.
The controller's maximum resolution 640x240 can't be supported at 2 bpp with the available RAM though.
So grayscale can be used but there isn't really support for taking advantage of this in current software. If you're making your own software then things are different of course and I can provide help for getting grayscale working with the USB13700.
PostPosted: Fri Mar 14, 2008 0:11
Dear Henri,
maybe you got some developer-stuff for your controller to read through? Even im not actually able to code c#,it would be interesting.
Cheers doc
Btw. Your display is on its way.
PostPosted: Sat Apr 19, 2008 11:31
And for some more eye candy check the video from here:
http://www.lcdstudio.com/forum/viewtopic.php?t=11064
http://www.closed-society.com/Optrex_DM ... r-XVID.avi
PostPosted: Sat May 17, 2008 18:02
I did 2 more Videos that shows the controller in "action".
First one with visualisations via winamp+lcdstudio running at 25fps:
http://www.youtube.com/watch?v=Ocycp7hBb4Q
Second one showing a vlc-videostream via the lcd. (Using jpg-transcode)
http://www.youtube.com/watch?v=mji09ngQ0-0
Cheers
:D
PostPosted: Sun May 18, 2008 17:41
Some original-footage:
640x200, winamp-controlled dancing crowd with lightning:
http://www.closed-society.com/lcd_image ... g-XVID.avi
Users browsing this forum: No registered users and 46 guests
