It is currently Wed Nov 11, 2026 5:45
PostPosted: Mon Apr 21, 2008 20:23
Hello all!
I obtained an MS240128A display with T6963C chipset.
I have a ATMega128 project that connects to the following:
1 GND Ground
2 VCC +5V
3 V-IN -5V to 0 Contrast
4 C/D Command write / Data write 5 RD Read data
6 WR Write data
7 DB0 Data bus line 1
8 DB1 Data bus line 2
9 DB2 Data bus line 3
10 DB3 Data bus line 4
11 DB4 Data bus line 5
12 DB5 Data bus line 6
13 DB6 Data bus line 7
14 DB7 Data bus line 8
15 CE Chip enable
16 RESET Reset
17 V-OUT -5V out
18 GND Mode
19 FS1 Font select
20 GND
The Datasheet on the display is this:
01 FG
02 VSS
03 VDD
04 VO
05 /WR
06 /RD
07 /CE
08 C/D
09 Reset
10 DB0
11 DB1
12 DB2
13 DB3
14 DB4
15 DB5
16 DB6
17 DB7
18 FS
19 VOut
20 Anode
21 Kathode
22 NC
23 ED
24 CData
25 FR
26 LP
27 HSCP
28 NC
29 VDD
30 VSS
31 VO
32 VOut
33 Anode
34 Kathode
There are some items i do not understand...
How to wire this one according the 1st given values?
Manny Regards,
Ferry
PostPosted: Sun Aug 31, 2008 14:01
Hi there, this is Alan
I'm working on a same LCD labeled MS240128A.
What is your trouble?
We may discuss about it together^_^~
I'm currently working with the datasheet of another LCD using T6963C as a substitute.
Could you send me a copy of the datasheet?
I wanna figure out if the pin def are exactly the same~
Many thanks~
My E-mail is cheetahxun@gmail.com
