It is currently Sun Nov 08, 2026 12:57
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Dec 31, 2002 17:54
I can't tell you if it works... but it works in the way that both codes never end in an endless loop.
I did some tests with different images (geometric forms) and it seems that the pixels are not set on the correct position.
The reason could be in the SetLCDPixel function. I didn't know what font_width was, so I thought it is the width of each character. This would be 6 pixels with my display (because of the 6x8 font set).
Was this right?
The answer to all questions is 42
PostPosted: Tue Dec 31, 2002 18:05
If it hangs it is a sign that the code isn't right. You could try adding some delay in place of the statuscheck before I figure out how the status check works.
This is from Yarvieh (the maker of LCDStudio) and it can be used to create small delays. I'm not sure how easy it is to convert to visual basic but I'm sure it has some way to create delays.
void MicroDelay(long microseconds)
  LARGE_INTEGER liFreq;
  LARGE_INTEGER liCnt;
  LARGE_INTEGER liStart;
  LONGLONG ticksPerMilliSec = 0;
  if ( QueryPerformanceFrequency(&liFreq) )
    ticksPerMilliSec = (liFreq.QuadPart)/1000000;
  else
  // MessageBox(NULL,"Error obtaining frequency\n",0,NULL);
  if ( QueryPerformanceCounter(&liStart) )
    do
      QueryPerformanceCounter(&liCnt);
    }while ((liStart.QuadPart + (__int64)(ticksPerMilliSec * microseconds)) > liCnt.QuadPart);
The font_widht is what you thought. It should be 6 if used with 6x8 font.
PostPosted: Tue Dec 31, 2002 19:25
It does not hang, it seems to work correct.
When I display text, it is displayed perfectly without any characters or pixels left out.
Here are pictures of my geometric test:
PostPosted: Wed Jan 01, 2003 14:03
Hmm, so you can use the WaitDisplayReady() function without problems ? Because if it can't read the status flag it should go to infinite loop and hang the program.
Have you tried with some pause instead of WaitDisplayReady() ?
You could also post your code here or send it to me to check if I could notice anything strange in it.
PostPosted: Wed Jan 01, 2003 15:46
I have written this to wait for the display:
Public Sub WaitDisplayReady()
Dim lngTmp As Long
Dim lngDiff As Long
lngTmp = GetTickCount()
Do Until lngDiff > 2
    lngDiff = GetTickCount() - lngTmp
    DoEvents
Loop
End Sub
It waits 2 ms to do the next pixel. So it takes about 5 minutes to draw the whole display. This is quite interesting to see in which order it draws the pixels. I will try to describe it (pixel 0 starts in the upper left corner):
It starts at (0|0) and ends at (127|127). It goes like this: (0|0), (0|1), (0|2)... until (0|127) and then starts at (1|0) and goes till (1|127) and so on. But it jumps in the columns. After the first three lines, it jumps to line 5 or 6 and draws there 3 lines, then jumps back to fill the gap with the content that should have been elsewhere. This is why the picture I posted above looks that strange.
It could be caused by the modulo calculation. Here is my code that draws a pixel:
Public Sub SetPixel(intX As Integer, intY As Integer)
Dim intAddr As Integer
intAddr = intGBase + (intY * intBytesPerRow) + (intX / 6)  'calculate place in memory
Call WriteData(intAddr And 255) 'write calculated address
Call WriteData(RShiftLong(intAddr, 8)) 'write calculated address
Call WriteCommand(36) 'set cursor
Call WriteCommand(248 Or (6 - 1 - (intX) Mod 6))
End Sub
PostPosted: Wed Jan 01, 2003 16:18
I have analyzed the way the lines are drawn. This is a list in which order the lines are drawn. On the left is line 1 which starts at (0|0) and goes to (0|127):
01 02 03 04 -- -- 07 08 09 -- 05 06 13 14 15 10 11 12 19 20 21 -- 17 18 25 26 27 22 23 24 31 32 33 -- 29 30 37 38 39 34 35 36 43 44 45 -- 41 42 49 50 51 46 47 48 55 56 57 ...
it should have been:
01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
Those are always blocks of 11 lines, seperated by a blank line (--). Only the beginning is different.
I will try to find out the scheme that lies behind this line shifting.
PostPosted: Wed Jan 01, 2003 19:27
I did not come any further, but made a small graphic to analyze the shifting:
The light red squares are lines that are drawn over the yellow lines.
I think the problem lies in the SetPixel function. Something with the calculation must be wrong. I have experimented with it a little, but always got strange results...
PostPosted: Wed Jan 01, 2003 23:59
More code for you:
It draws a bitmap to the screen using the block write mode of t6963c.
void cT6963C::DrawAnimFrame(Graphics::TBitmap *frameBitmap, int x, int y)
  int addr;
  for(int i=0;i<frameBitmap->Height;i++)
    // set address pointer to beginning of row
    addr = G_BASE + ((y+i)*BYTES_PER_ROW) + (x/font_width);
    T6963C.WriteData(addr & 0xFF);
    T6963C.WriteData(addr >> 8);
    T6963C.WriteCtrl(0x24);
    T6963C.WriteCtrl(0xB0); // auto write mode on
    for(int j=0;j<frameBitmap->Width;j++)
      BYTE lcdValue = 0;
      // build the byte to send to display
      for(int k=0;k<font_width-1;k++) // add all bits except last one
        lcdValue |= (frameBitmap->Canvas->Pixels[font_width*j+k][i]!=0 ? (byte)0 : (byte)1);
        lcdValue <<= 1;
      lcdValue |= (frameBitmap->Canvas->Pixels[font_width*j+5][i]!=0 ? (byte)0 : (byte)1); // add
last bit to byte
      T6963C.WriteData(lcdValue);
    T6963C.WriteCtrl(0xB2); // auto write mode off
PostPosted: Thu Jan 02, 2003 0:12
Thanks!
It looks like BorlandC++.
But I don't understand those lines:
lcdValue <<= 1;
What do "|=", "?" and "(byte)0 : (byte)1" do?
PostPosted: Thu Jan 02, 2003 0:38
I just made my first ever visual basic program to calculate these:
VB: (248 Or (6 - 1 - (intX) Mod 6))
C: (0xf8 | (6-1-(x % 6)))
I tried them with different values but couldn't notice any difference.
The following is from C++ Builders help:
In the expression E1 ? E2 : E3, E1 evaluates first. If its value is true, then E2 evaluates and E3 is ignored. If E1 evaluates to false, then E3 evaluates and E2 is ignored.
Example:
lcdValue = bitmap[x][y]!=0 ? 0 : 1;
If bitmap[x][y] is 0 then store 1 to lcdValue if bitmap[x][y] is something else store 0.
EDIT: I ignored the ! sign in the above explanation but I changed it now.
Then
lcdValue |= bitmap;
is same as
lcdValue = lcdValue | bitmap;
But then what this means ?
lcdValue |= bitmap[x][y]!=0 ? 0 : 1;
lcdValue <<= 1;
Below is lcdValue in different stages:
00000000 <- lcdValue in the beginning
00000001 <- 0 found from bitmap[x][y] -> inverted to 1-> ORred to lcdValue
00000010 <- left shift lcdValue with 1
00000011 <- 0 found from bitmap[x][y] -> inverted to 1-> ORred to lcdValue
00000110 <- left shift lcdValue with 1
00000110 <- 1 found from bitmap[x][y] -> inverted to 0-> ORred to lcdValue
00001100 <- left shift lcdValue with 1
Hope this makes some sense, teaching these to others just isn't my thing :wink:
PostPosted: Thu Jan 02, 2003 2:03
lcdValue <<= 1;
I didn't know what <<= does, but now I know that it is left shifting :)
I ported your code to VB and it works! :D
This is the code:
Public Sub DrawBMP(picPicBox As PictureBox, intX As Integer, intY As Integer)
Dim intI As Integer
Dim intJ As Integer
Dim intK As Integer
Dim lngLCDValue As Integer
Dim intTmp As Integer
For intI = 0 To 127
    'set address pointer to beginning of row
    intAddr = intGBase + ((intY + intI) * intBytesPerRow) + (intX / 6)
    Call WriteCommand(176) 'auto write mode on
    For intJ = 0 To 127
        lngLCDValue = 0
        'build the byte to send to display
        For intK = 0 To 4 'add all bits except last one
            If picPicBox.Point(6 * intJ + intK, intI) <> 0 Then
                intTmp = 0
            Else
                intTmp = 1
            End If
            lngLCDValue = lngLCDValue Or intTmp
            lngLCDValue = LShiftLong(lngLCDValue, 1)
        Next intK
        If picPicBox.Point(6 * intJ + 5, intI) <> 0 Then
            intTmp = 0
        Else
            inttmo = 1
        End If
        lngLCDValue = lngLCDValue Or intTmp 'addlast bit to byte
        Call WriteData(lngLCDValue)
    Next intJ
    Call WriteCommand(178) 'auto write mode off
Next intI
End Sub
But there are irregular graphic errors, but I think they don't have to do with the code but with the display itself. Even when I use LCDInfo to display some bitmaps I get those graphic errors. Each time I display the same bitmap the errors are different. Mostly they are shifted lines. Here is a picture as an example:
The text is always correct.
Are there any registers in the RAM or ROM of the display that are saved even when the computer is switched off? Maybe they are set wrong in this is the cause for the errors. And do I need to perform any commands to prepare the display to be shut off? Something like I the initialization.
PostPosted: Thu Jan 02, 2003 2:24
That may be because of writing too fast to the lcd. Adding busy flag checking just before writing the data byte might fix it. Unfortunately auto mode has it's own busy flag checking and I haven't got the code for that working. But you could try adding a slight delay before the Call WriteData(lngLCDValue) line. This would confirm if that's the problem.
Also LCDInfo doesn't yet have busy flag checking implemented for your wiring. I'm hoping to have user definable wiring in the next LCDInfo version so after that there shouldn't be worries of different wirings anymore.
I don't know of any registers that would retain their values after power off. Also I'm not aware of any shutdown routines needed.
PostPosted: Thu Jan 02, 2003 2:39
I also noticed that you have hardcoded the picture size to 128x128 in your code. In this case it isn't necessary to set the memory pointer to the beginning of a next row in the outer loop. You can just set the memory pointer to G_BASE before the loops. This way you get rid of some unnecessary work and your program should work faster.
The code I posted works for smaller bitmaps too.
PostPosted: Thu Jan 02, 2003 13:49
This is strange, because in the first days when I had the LCD everything worked fine with LCDInfo.
I added a delay before writing and it fixes most of the shifted lines. But there are still a few graphic errors, which are visible only at the second sight. I made a test graphic where every second line (horizontal and vertical) is black, the next white. When using your algorithm, every 6th line horizontal is left out. The vertikal lines are ok. Then I changed something in the code:
For intK = 0 To 4
to
For intK = 1 To 5
and
to
If picPicBox.Point(6 * intJ + 6, intI) <> 0 Then
With this change the lines are no longer left out.
But there are still small errors in the drawn picture, everytime at the same position.
I will try to find out how to read the busy flag for my wiring.
And I am looking forward for the next version of LCDInfo :) If I can help you with testing, just let me know!
PostPosted: Thu Jan 02, 2003 14:13
Hmm, when was that and what LCDInfo version were you using ?
Maybe you found a bug in my code or some thing that works differently in VB.
Some new code including busy flag reading for all wirings is coming soon...
Ok, you could email me and I will send you a test version. There should be something to test pretty soon.
Users browsing this forum: No registered users and 42 guests
