It is currently Sat Nov 07, 2026 19:52
 Post subject: serial t23a connection
PostPosted: Mon Jan 31, 2005 17:51
Can someone tell me how to connect the Noritake T23A via serial. I've only been able to find parallel connection info.
PostPosted: Thu Feb 03, 2005 0:50
It just needs a level converter with MAX232 or some equivalent function IC.
The serial input pin is pin 11 in the IDC data connector or then the middle pin in the 3 pin power connector. You can use either one of these.
Here is an example using MAX232:
http://chaokhun.kmitl.ac.th/~kswichit/MAX232/MAX232.htm
So you just connect the signal coming from the PC serial port TXD pin through the level converter to the VFD serial input pin.
PostPosted: Mon Mar 07, 2005 19:59
Thanks Henri. Is there a benefit to serial. Lower CPU usage? High compatability? Easier to program?
PostPosted: Mon Mar 07, 2005 22:52
I don't know if there's that much benefit using serial. Parallel should be faster but with a character display like this speed should't be a problem. Someone might like to connect it to serial port and someone to parallel.
Then there's of course the issue that some PC's don't have parallel port. Anyway if you have a display wired with either way and it's working I don't see reason to change. Also if you're just planning to wire the display it's up to you to decide which method to use. There shouldn't be any difference in functionality.
