It is currently Sun Nov 08, 2026 7:20
PostPosted: Wed Jan 29, 2003 4:46
i have written a T6963C-displaydriver, that can be used with all possible displaysizes.
U can find it here:
http://rogue.wh20.tu-dresden.de/~maik/glcds/eigenes/mlcdp/TreiberTest.zip
Unfortunately its in german, but if you wish I translate it.
Look at the T6963C.ini and setup your displayconfig.
At the moment there are only 3 configs in it, because i have only these 3 displays, but its very easy to add new displaysizes.
Thanks.
PostPosted: Wed Jan 29, 2003 11:44
Hehe, that config file looks very much like what's in the latest LCDInfo version (not released yet).
I'll test that when I get home.
PostPosted: Thu Jan 30, 2003 10:38
This is some copy/paste from another topic: http://www.skippari.net/phpBB2/viewtopic.php?t=112
Henri wrote:
I don't have a T6963C display using the Pollin wiring (i guess that's what you're using) at hand right now so I only was able to use the virtual lcd in the driver test but I can test this later.
MaikRutsche wrote:
You have a different wirring?
All paramters are seperate adjustable.
If you give me a schematic of your wiring then a could make a new option in the driver.
Henri wrote:
Yes, I have a display with the powerlcd wiring to test wiring settings in the new LCDInfo version. In that you can define yourself how you have the pins connected.
But I also have a 240x64 display with the pollin wiring so I should be able to test your drivers soon.
/* pollin*/
int wr=1;
int rd=17;
int cd=16;
int ce=14;
/* powerlcd*/
int wr=16;
int rd=14;
int cd=17;
int ce=1;
MaikRutsche wrote:
So here is the new Version:
Driver-Testprogram:
http://www.wh19.tu-dresden.de/~maik/glc ... erTest.zip
Look at the T6963C.ini and you will find 4 new options:
Pin_WR=1
Pin_CE=14
Pin_CD=16
Pin_RD=17
PostPosted: Thu Jan 30, 2003 10:41
I tested the driver with a 240x128 display using the powerlcd wiring but wasn't able to get it working. I was using the 240x64 setting but this shouldn't matter, I guess.
With 240x64 display and pollin wiring it worked fine.
I'll do some more testing tonight.
PostPosted: Thu Jan 30, 2003 15:25
I have found the problem.
The powerlcd-wiring is a little tricky because it use an not very clever wiring.
The normal wiring connects inverted display pins to inverted lpt pins, the powerlcd wiring connects the inverted pin (WR) to a non inverted lpt pin (16 = Init) and a non inverted lcd pin (CD) to an inverted lpt pin (17= Select In).
PostPosted: Thu Jan 30, 2003 15:45
I'm sure you have already figured it out but if you wan't see how I did it here's some code: http://www.skippari.net/phpBB2/viewtopic.php?p=555#555
PostPosted: Thu Jan 30, 2003 16:15
I updated my programm:
http://rogue.wh20.tu-dresden.de/~maik/g ... erTest.zip
Pin_WR=16
Pin_CE=1
Pin_CD=17
Pin_RD=14
Should work now.
PostPosted: Thu Jan 30, 2003 21:05
Hmm, I tried to download it from that link but got the old version ?
PostPosted: Fri Jan 31, 2003 2:55
It was the wrong link, now it should be the new version
PostPosted: Fri Jan 31, 2003 9:26
Now I quickly tested it with the 240x64 settings with 240x128 display and didn't notice any problems. I'll do more testing and the 240x128 config later today.
PostPosted: Fri Jan 31, 2003 17:13
Nice :)
If you want to play a little bit more, here's my a testversion of my programm:
http://rogue.wh20.tu-dresden.de/~maik/g ... .01.31.zip
Could you post your config for the 240x128?
PostPosted: Fri Jan 31, 2003 21:29
This is what I did for 240x128 display:
[Disp240x128]
TextRows=16
TextColumns=40
GraphRows=128
GraphColumns=40
BitsPerGraphColumn=6
TextHomeAddress=$0000
GraphHomeAddress=$0300
;CGRamHomeAddress=$1000
CGRamHomeAddress=$0002
I didn't make any changes to the CGRAM settings so...
I need to have a look at that later.
