It is currently Mon Nov 09, 2026 6:00
PostPosted: Mon Feb 03, 2003 16:58
Everybody seems to be writing Blinkenlights players now but I wasn't able to use any of them so I wrote my own for the Noritake vfd. I wrote this in about 20 minutes so you'll probably find many bugs and I've only tested it with the two movies included in the zip. If you find any bugs/problems you can report them here and I might do something for them. This is a command line tool again like the previous player so you run it something like this:
blinken animation.blm
Download the player here:
http://www.skippari.net/lcd/sekalaista/ ... lights.zip
You can find more movies here:
http://www.blinkenlights.de/
The player is made for Zotty's wiring that you can find here:
http://zapour.student.utwente.nl/schijf ... .php?t=107
Edit:
I just found a bug and updated the program.
PostPosted: Mon Feb 03, 2003 20:17
Hehe, nice. Works fine for me!
Hello Henri btw, /me waves :)
PostPosted: Mon Feb 03, 2003 21:59
Good to hear that it works for you. :)
PostPosted: Mon Feb 03, 2003 22:06
And here's a FLECOM Special Edition of the prog:
http://www.skippari.net/lcd/sekalaista/ ... flecom.zip
PostPosted: Thu Feb 20, 2003 3:06
Is there an app that will allow me to run full screen animation on the 800, 128x64.
Using the big fat parrallel pipe we should be able to do some really cool start-up anims.
PostPosted: Thu Feb 20, 2003 10:10
How about this: http://www.skippari.net/phpBB2/viewtopic.php?t=121
PostPosted: Fri Feb 21, 2003 5:52
I have created a couple, and would love to see what others have done.
:twisted:
PostPosted: Fri Feb 21, 2003 8:57
You could show everyone else an example and post yours. :wink:
If you don't have a place to host them just email them to me and I'll put them up.
I'd also love to see some animations.
PostPosted: Fri Feb 21, 2003 15:10
Well , what can i say , it sema great , but , can you do one for the rest of the LCD tipes of LCD's ??
SAmtech
XP 2000+
A7N8X Dlx
256 Mb DDR PC3200 OCZ
GF 4 Ti 4200 128 DDR
180 Gb
Studio PCTV Pro
PostPosted: Fri Feb 21, 2003 15:43
Ok, you asked for it: http://www.skippari.net/lcd/sekalaista/ ... lights.zip
It doesn't look very good because it clears the lcd between every screen but maybe I could make a better version sometime.
PostPosted: Mon Jul 21, 2003 10:47
i think in this case you should befoir read DATA, then write with XOR or AND operation.
it is bad that LCDs does not support this operations :( only : READ/WRITE
PS:maybe also it is possible to store all lcd data in PC ram, faster.. etc
PostPosted: Mon Jul 21, 2003 23:18
Yes, this can be made better in many ways. Using some buffer in PC ram might be a good solution. If you want you could make some optimizations to the code. ;)
It is possible to use the XOR and AND with the buffer in PC ram and I've already used that in other programs with KS0108.
