It is currently Fri Oct 23, 2026 16:57
PostPosted: Mon Jan 12, 2009 13:50
Linux framebuffer driver for USBD480 is something that I have also been working on. The driver is working but still needs more testing and cleanup.
Just letting you know that it would be one possible way to use the display in Linux. Of course direct access from user space with libusb works fine also and for many applications can be the preferred method.
PostPosted: Sun Jan 25, 2009 15:54
A short video of the framebuffer driver in use is posted here.
http://www.youtube.com/watch?v=u2arP05jpHA
It shows the fbplasma demo running on the fb device. The video is recorded at 15 fps do to the limitations of my recording equipment so it's not exactly accurate representation of how it works. But at least it should show that for some applications the framebuffer device can provide good enough performance with the USBD480.
PostPosted: Tue Feb 17, 2009 18:17
Here is now a little video showing Qt Embedded with Linux used with USBD480:
http://www.youtube.com/watch?v=zcQlxs_BjFQ
It's working better than I had expected. With the standard frame buffer device it should be possible to also run X on it but haven't tested yet.
The video quality is still horrible. I really need to arrange better camera, more light and experiment a little to produce some videos where you can actually see something...
PostPosted: Tue Feb 17, 2009 18:25
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zcQlxs_BjFQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zcQlxs_BjFQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
PostPosted: Mon Jan 31, 2011 22:16
Hello all
Do you have the source code for framebuffer and patching instructions (better if 2.6 but any kernel version is fine)? If this code is outdated, I can try to make it work again...
I am trying to use splash screen boot through the LCD so none of the other options (library or X) would work. The resource pointers in this forum do not include this info, or at least I have not been able to find it.
Many thanks
David
PostPosted: Wed Feb 13, 2013 16:41
Was this ever finished? I can't find a link to it anywhere...
Maybe some instructions on how to use it?
Would be super awesome :)
