It is currently Mon Oct 05, 2026 2:30
PostPosted: Wed Apr 07, 2010 23:52
Does anyone have information on the LCD panel from Epson CX8400 Printer? Datasheet, controller etc?
I don't even know the dimensions of this LCD, but its pretty big (used image editing software to "estimate" the size -- roughly 325x260).
Chip on the back reads Epson E09A 81AA G7606. Couldn't find anything about this chip on the web. (Please see the attached pic.)
I am guessing the chip on the back actually is a micro of some sort. I don't have access to any probing equipment :( so please help.
Thanks,
_Kyle
PostPosted: Tue Oct 26, 2010 8:17
I recently pulled a color LCD from an Epson Stylus Photo R390. It is a 3.5" LCD, 320x240 QVGA. I found the service manual for this all-in-one printer/scanner and the pinout is below. Your LCD only has 9 pins, but may have similar signals.
My LCD had numbers on the PCB and numbers on the Epson controller IC. I assume that they were in-house numbers, as I couldn't find data on any of them.
I haven't tried programming my LCD yet, so I'm not sure of the proper method. At a guess, maybe the SDATA0-SDATA2 lines are to be loaded with successive RGB values, strobing the SCLK line for each one. If that is how it works, then this display would work like a raster CRT, painting each line until the screen is filled. This is purely a guess, however. If anyone knows different, please educate me.
1 - GND
2 - SCLK
3 - GND
4 - SCE
5 - SDATA0
6 - SDATA1
7 - SDATA2
8 - GND
9 - PNLRST (active low)
10 - +3.3V
11 - +3.3V
Users browsing this forum: No registered users and 157 guests
