It is currently Mon Oct 05, 2026 6:36
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Sat Oct 25, 2003 15:51
Latest version can be downloaded here:
http://www.skippari.net/lcd/alpha/lcdinfo_test.zip
Known bugs:
* BACKGROUND IMAGE (fullscreen bitmap) REQUIRED FOR GRAPHICS TO WORK PROPERLY
Build 18
[features added]
* Plugin configuration dialogs can be launched from LCDInfo menu
* SED1520 driver comes in the package
* SED1565 driver
* Noritake CU20045SCPB-T23A driver
* Noritake GU128x32-311 driver
Build 17
[features added]
* Driver for Crystalfontz 631
* Driver for Crystalfontz 633
* Driver for Crystalfontz 632/634
* Driver for Noritake GU256x64-372 VFD
* Foobar2000 plugin
* iTunes plugin
* Winamp3 plugin
Build 16
[changes]
* T6963C driver timing changes. Takes more cpu time but fixed corruption for me.
* Changed buffer from 1bpp to 8bpp to simplify things and for possible future expansion
[bugs fixed]
* Part of bitmap not shown if width not multiple of 8
* Corruption with KS0108 and Noritake800 drivers if image position was not multiple of 8
* Separate erase at screen change removed to prevent flashing
[features added]
* More variables in SysInfo plugin
* Circle, Box, Degreeline, Fill, Bitmap join for plugin writers
* 6x8 font support for SED1330/SED1335 driver
* Philips PCD8544 (Nokia lcd) driver
* Flags (Winamp.Playing etc...)
* Delay option for KS0108 driver
Build 15
[changes]
* Data interface changed a lot so new SDK is needed. Plugin developer also needs to derive from DataSource instead of IData now.
[bugs fixed]
* Better binary compatibility between different compilers. SDK should now support writing plugins with Borland C++ Builder also.
[features added]
* LCDInfoApi functions to enumerate data variables and to get information about current display driver
* Simple UI interface
* WMP plugin - check the forum for more information about the plugin
Build 14
[changes]
* Displaydriver interface changed so newest SDK is needed
* Variable names in most plugins had changes and have same format now
[bugs fixed]
* Long delay at start that occurred on some systems
* Float/double mixup in SDK that caused access violation is certain situations
* If there was spaces in plugin variable id it was not recognised
[features added]
* More Winamp2 plugin variables
* MBM5 plugin
Build 13
[bugs fixed]
* T6963C driver configuration dialog bugs
* SED133x driver configuration dialog bugs
* Plugins didn't load with win95/98/me
* Text scrolling 2 characters at a time
* Textdata couldn't have spaces in it
* Rewrote 6x8 font graphics drawing in T6963C driver
[features added]
* Support for more than one screen
* Simple action support for changing screens
* BA63/66 character VFD driver
* Z-World OP6400 driver for text mode
Build 12
[bugs fixed]
* Fixed binary incompatible plugins included in build 11
Build 11
[features added]
* Winamp 2 plugin showing visualization and title
Build 10
[features added]
* Network statistics plugin
* Log file is deleted at program start
Build 9
[features added]
* Zoom Player plugin
Build 7
[features added]
* T6963C driver
* Noritake 800 graphical VFD driver
* SED1330 / SED1335 driver
Build 6
[features added]
* duty ratio selection for LC7981 driver
Build 5
[features added]
* animation support (bugs in drawing)
[bugs fixed]
[known bugs]
* previous animation frames are not erased if there's no background image
PostPosted: Sat Nov 29, 2003 14:43
Here's now build 13 which should fix some bugs and also run on win9x systems now. There's also support for more than one screen and simple action support for screen changes.
PostPosted: Fri Dec 05, 2003 14:50
Were can I find build 14?
Rudi Grobler
PostPosted: Fri Dec 05, 2003 17:13
Build 14 now available. Variable id's have changed so if you have done your own screen files you might need to do some changes. You can see all available variable id's in the log.txt.
PostPosted: Thu Dec 18, 2003 23:23
Build 15 available. There are not much changes for the regular user but more changes have been done under the hood and in the plugin SDK.
PostPosted: Sun Feb 22, 2004 12:59
Build 16 available. There were many changes so it's possible that some bugs slipped through. Also all graphics display drivers experienced a rewrite in some parts but I tried to test them all.
If there are any problems let me know.
PostPosted: Wed Feb 25, 2004 3:36
thx henri
£+µ :D
PostPosted: Sun Apr 11, 2004 17:07
Build 17 available. There isn't much new stuff unless you've been waiting for those drivers and plugins that were added. Next build should have more new features.
Also it's now zip instead of rar.
PostPosted: Wed Dec 15, 2004 18:32
LCDInfo (Build 19)
An update is ready for LCDInfo. Have planned a few more features. Hope you don't mind me releasing Henri? I'll sort out the updated source code tomorrow.
Updates:
  • Fixed Dialog Layout: Fixed up the layout of the "Configure Plugins" and "Select Driver" dialox windows.
  • Added Variable Viewer: In the "Configure Plugins" dialog, you can now view all the plugin's variables by wither double-clicking on the plugin in the list or selecting the plugin and clicking the "Variables" button.
  • Windows XP Theme Support: LCD Info should now display with proper the proper Windows XP theme when used on the Windows XP operating system.
  • Start LCDInfo With Windows: There is now an option in the system tray menu to automatically start LCDInfo when windows starts.
Download:
http://users.on.net/~krakken/LCD/lcdinfo.exe (Overwrite current EXE)
http://users.on.net/~krakken/LCD/lcdinfo.exe.manifest (Put in same directory as EXE)
PostPosted: Wed Dec 15, 2004 23:48
KrAkKeN,
Dunno if it's a bug or if you planned it that way, but when I use the X to close the variables window, nothing happens. :) I have to actually click the close button.
Other than that... Thanks Dude, you rock :!: ;)
PostPosted: Thu Dec 16, 2004 2:45
Updated :)
Seems I _did_ have the code but I was checking for the wrong command.
PostPosted: Thu Dec 16, 2004 22:26
No problem, glad to see someone else also doing something with it. :wink:
PostPosted: Thu Jul 07, 2005 19:59
KrAkken could you post the lastest source, I got some changes I want to make too.
Right now I am working on a full media control center where the vfd is the only screen and it shows media info plus lets you go through directories and all. I figure I should do this for LCDinfo now because of the huge lcd/vfd support instead of just my current vfd. But in order for me to do this I need to add to LCDinfo a way for a plugin to send a message to LCDinfo to load a new screen.xml file for different screen configurations thats going to be needed. If you dont want to post the source here could you maybe email me it? thanks.
PostPosted: Sat Jul 23, 2005 22:27
KrAkKeN wrote:
LCDInfo (Build 19)
Updates:
Download:
Just quits when I start it up, no error or anything...
Edit: Sorry, my mistake, works fine :)
- Rexxie
PostPosted: Thu Jul 28, 2005 2:30
I found it! I meant to put it up a long time ago but unfortunately, in one of my worse days, my organisation went out the window and I accidentally deleted it. Luckily for me Henri had a copy that I sent him so here it is. Sorry about the _huge_ delay.
It's currently hosted on my home server so if anyone could make a copy or upload it here possibly Henri? The server is always up so don't worry about that but in 6 weeks i'm moving _again_ so I won't have the internet for a short while.
http://www.sapian.net/downloads/lcdinfo ... 7_2005.zip
Enjoy.
Users browsing this forum: No registered users and 46 guests
