It is currently Mon Nov 09, 2026 19:57
PostPosted: Tue Dec 09, 2003 16:11
PostPosted: Thu Dec 11, 2003 9:48
I think you need to be slightly more specific ;)
Do you have some question about HD61830 ?
PostPosted: Sat Jan 24, 2004 13:36
Ok, here is some help, my library for HD61830 (put on a LMG6401PLGE display). It is written in DOS, but it's faster than Windows libraries because most of them use DLPortIO driver, which is quite slow.
Since I don't have much experience with Windows programming, next one will be a library for microcontrollers (Atmel MEGA and then PIC16 or 18), maybe with a small digital oscilloscope application if this period of coming home from work at 10 in the evening will come finally to an end... :evil:
here is the link (with thanks to Henri):
http://www.skippari.net/lcd/sekalaista/lcd_hd61830_lib.zip
PostPosted: Sat Jan 24, 2004 16:39
Hey, this sounds very interesting. If you get to work on this I'd like to know more about your design.
Have you thought of what kind AD converter you'd use ?
PostPosted: Mon Jan 26, 2004 10:03
You will get the entire code for it :) . I was thinking about a not too powerfull application using the internal A/D (works just fine) in the case of ATMEL and bigger PICs. Of course, smaller controllers don't have it so it will have to be an external one but again, if I try to use a fast parallel converter, I will not have enough pins on the controller for A/D and graphic LCD, and with a serial converter, it will be slower, decreasing the maximum frequency to be displayed. Anyway, first will be AT MEGA8 (8k FLASH, 1K RAM, A/D, serial com, 512 bytes EEPROM, lots of pins).
The only problem is that the work doesn't allow me to do anything extra at this moment, I hope that this will be the last week of this busy period.
Anyway, I will keep you informed ...
