It is currently Mon Jan 21, 2019 1:07
PostPosted: Sun May 23, 2004 21:23
Can u please let me know the display size of 8210 if the controller used is PCD8544.
I have displayed CUSTOM LOGICS ,with CUSTOM on one line and LOGICS on the second line. It works fine for all the other LCD,however when it comes to 8210 ,the display is something wierd :?
I get the last two lines full black and CUSTOM on the third last line while LOGICS on fourth last line.
What can be the possible problem .
Pravin
PostPosted: Mon May 24, 2004 22:09
pravin wrote:
Pravin
My belief has been that 8210 used 84x48 display with PCD8544 controller. But I've never tested it myself.
So are you testing the display with LCDInfo ? Or some of your own code ?
If I'm not completely mistaken I think someone used 8210 display with LCDInfo succesfully.
 Post subject: 8210
PostPosted: Tue May 25, 2004 13:56
Hi Henry,
I am checking i with the microcontroller code which i have wrote.
I have the same code working for other LCD supported by PCD8544
Pravin
 Post subject: problem solved
PostPosted: Wed May 26, 2004 18:52
Henry the problem is solved ,it was because of the rubber pad ,probably got damaged . its working fine with new rubber pad
Thanks for the help henry
Pravin
