It is currently Fri Oct 23, 2026 3:06
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jun 09, 2004 14:45
You can get the basic LCDInfo driver for this display from here:
Parallel mode: http://www.skippari.net/lcd/alpha/plugi ... driver.dll
Serial mode: http://www.skippari.net/lcd/alpha/plugi ... driver.dll
Here's some information you can use to make the connections:
http://www.vfdworld.com/index.php?page=usingyourvfd
It's not very extensively tested but it might work ;)
The driver has been developed with the CU20045SCPB-T23A display but it might work with other SCPB-T series displays. If you test it with some other display please report your results here.
PostPosted: Wed Jun 09, 2004 17:24
Well it sure works :P
Check out my leet ghetto display stand :x
PostPosted: Wed Jun 09, 2004 21:28
is there a spectrum?
PostPosted: Fri Jun 11, 2004 17:24
I have the driver and the plugin for winamp. When I run LCDinfo all I get is the artist name over and over. Do I need to do something special to get this to work?
PostPosted: Sun Jun 13, 2004 8:48
I assume you know how LCDinfo 0.6 works. I think you should make some screens. If you have an output, it means the display is ok, just edit the screens accordingly.
PostPosted: Wed Sep 08, 2004 14:29
Okay, maybe I'm just a bit slow.... But how do I install the driver? :oops:
I tried last night, by copying the DLL into the LCDInfo directory.... But it didn't seem to have any real effect. What should happen here? I get a new device in the radio-group?
PostPosted: Wed Sep 08, 2004 19:02
Are you using the 0.6 version of LCDInfo ? Radio group somehow sounds like 0.3 series LCDInfo. In 0.6 the driver should show up in the list of drivers when the dll file is put in the LCDInfo root directory.
PostPosted: Thu Sep 09, 2004 10:06
Oh, yes, right you are.... I guess I should pay attention when downloading software....
(Bangs head against table) STUPID, STUPID, STUPID!
PostPosted: Sat Sep 11, 2004 12:23
Thank you!
This driver works with my T20A :D
The only problem I have is that the cursor is not disabled... so I see it all the time moving around the display updating stuff.
According to my info, the T23A and T20A have the same "cursor off" command (16Hex).
Of note is that I found this same problem using LCDHype. But that made the display flicker horribly, lcdinfo is much better in that regard :)
I wish I could tell you what was causing this, but I don't know. I've wired the module to the serial port, and manually sent the 16Hex command to the module. That worked. It's only with these parallel drivers that it doesn't seem to work.
PostPosted: Fri Sep 17, 2004 15:46
Let's see, I'm not sure if the driver even sends the command to disable the cursor. Maybe it is disabled by default in the T23A. I need to check this from the driver sources.
PostPosted: Tue Oct 05, 2004 19:04
Henri wrote:
You can get the basic LCDInfo driver for this display from here: http://www.skippari.net/lcd/alpha/norit ... driver.dll
PostPosted: Wed Nov 03, 2004 0:17
Any updates on this? I've read in other forums that the cursor can also be controlled, e.g. special fonts, spectrum etc.
Has anybody gotten characters and not rubbish when using serial input?
-= Torro =-
PostPosted: Sat Nov 13, 2004 12:40
Here's an updated version of the T23A driver that has the cursor off command added to the initialization.
I have not yet tested it myself so please let us know what happens with it.
PostPosted: Sun Nov 14, 2004 3:05
Just tried the dll file, no luck getting rid of the curson on the t20a.
Not sure which cursor that is enabled on this VFD,
Underline Cursor On 14H
5x7 Block Cursor On 15H
Cursor Off 16H
...but the d0-d7 instruction 16H should turn of any cursor.
-= Torro =-
PostPosted: Sun Nov 14, 2004 19:21
Yes it was the 0x16 command that I added. But I noticed that I forgot to add any delay after the software reset command so I have now put a 100ms delay there. Might help or not but anyway the file is updated.
