It is currently Sat Oct 10, 2026 20:39
 Post subject: Wintek H12068 to LPT
PostPosted: Thu Jun 24, 2004 21:29
HELLPP :cry:
i cant found any datasheet with information about this graphic lcd
here you can found a photo of this lcd
thanks a lot
PostPosted: Sun Aug 29, 2004 1:26
I have nearly the same Display-Module. It´s the Wintek WD-H12067.
The Connector JP1 is also 18-Pin wide.
Also the Connector to the LCD-LSI is 46-Pin-wide.
I found some Information under the brown Plastic-Connector with the LSI-Chip glued on.
On the reverse Side of the brown Plastic this helpful Designation i found:
"SAMSUNG" and "KS0713TB-03"
With this i found another helpful Site:
http://www.touchpanel.de/eng/pdf/grafik/w128-6xx.pdf
I hope, this Display is somehow compareable.
PostPosted: Thu Nov 10, 2005 2:36
Hiya guys...
I've got both the displays, and the same question as you.... Datasheet for the modules do I can get or build an interface of some sort.
Have ya found out anything yet?
Have ya contacted wintek directly, cus otherwise I will... they must have some kinda support-kid sitting around just waiting for my email to show up :o)
Sincerely
Kenneth Andersen, Denmark.
Users browsing this forum: No registered users and 150 guests
