It is currently Wed Apr 08, 2026 16:43
PostPosted: Wed Dec 15, 2004 7:23
If you are running MBM then you can use the "lancher" feature to start LCDinfo when windows starts, its a bit of a hack, but works well.
Just set it to start at 0c, and use a sensor that does not exist (hence it reads 0c), you can also have it re-start LCDinfo if it dies. Works really well on my Win XP box.
Hope this tip helps someone else, if you found this tip helpful, send a small donation to ....... ;-)
PostPosted: Wed Dec 15, 2004 9:52
Good idea. I'll integrate a "Start With Windows" into the IDE.
PostPosted: Sat Jan 29, 2005 11:26
Thanks to KrAkKeN, this feature has been added to build 19.
Get it Here: http://forum.lcdinfo.com/viewtopic.php?t=387
