| starting LCD info automaticly http://forum.lcdinfo.com/viewtopic.php?f=10&t=946 |
| Author: | croc4 [ Wed Dec 15, 2004 7:23 ] |
| Post subject: | starting LCD info automaticly |
If you are running MBM then you can use the "lancher" feature to start LCDinfo when windows starts, its a bit of a hack, but works well. Just set it to start at 0c, and use a sensor that does not exist (hence it reads 0c), you can also have it re-start LCDinfo if it dies. Works really well on my Win XP box. Hope this tip helps someone else, if you found this tip helpful, send a small donation to ....... |
| Author: | KrAkKeN [ Wed Dec 15, 2004 9:52 ] |
Good idea. I'll integrate a "Start With Windows" into the IDE. |
| Author: | Syridian [ Sat Jan 29, 2005 11:26 ] |
Thanks to KrAkKeN, this feature has been added to build 19. Get it Here: http://forum.lcdinfo.com/viewtopic.php?t=387 |
