It is currently Sat Oct 10, 2026 8:46
PostPosted: Sun Feb 29, 2004 4:33
OK, I give up. Three hours of trying to find a lpt port wiring schematic for this thing is enough. Can any of the schematics posted prev. in the forums be applied to this particular display? It has a T6963C-0101 as per the data sheet with a ccl backlight with male 4 pin molex and 20 pin header in two rows of 10. I know how to solder, don't know jack about LCD's! Thanks for any help.
http://www.optrex.com/engcenter/manuals.asp
PostPosted: Tue Mar 02, 2004 13:58
The pinout seems to mostly match the one here: http://www.skippari.net/lcd/t6963c_schem.html
The exception I saw is INVERT function in pin 20. If you connect it to +5v you get inverted picture and if you connect it to ground you get normal picture.
DMF-50316N also has CCFL backlight and needs CCFL inverter to power it.
 Post subject: Thanks
PostPosted: Tue Mar 02, 2004 19:55
Thanks for the information Henri. I'll give it a try using that schematic. I just wonder what color the smoke will be....
PostPosted: Fri Aug 04, 2006 4:25
How did it go??? I also need help with this display
PostPosted: Fri Aug 04, 2006 12:12
What exactly did you need help with?
PostPosted: Fri Aug 04, 2006 14:48
i need to know if the pinout even worked and im gona need help backlighting it because the ccfl is dead. thats what i was told
EDIT: ive got one of these also and dont know where to start.
PostPosted: Fri Aug 04, 2006 19:27
For the the Optrex 240x64 you can use any T6963C to LPT wiring scheme, for example this one.
Hook up the CCFL to a modding CCFL Tube inverter and check that, if it's dead then it might be near impossible to find a replacement. Since the diffuser is already in place you could try it with some LEDs.
Your second LCD looks kinda harder to hook up, you'll need datasheet.
PostPosted: Sat Aug 05, 2006 19:13
That second LCD looks as if it's controllerless and the chip which can be seen may actually be one of the driver chips, perhaps the row driver.
http://mylcd.sourceforge.net/
PostPosted: Mon Aug 07, 2006 22:13
the optrex screen after i wire this up what program would i use on my pc
Users browsing this forum: No registered users and 159 guests
