It is currently Thu Nov 12, 2026 19:30
PostPosted: Thu May 03, 2007 13:27
Good afternoon! I apologize for my bad English. I from Russia.
There is at me a display from phone Motorola C156.
I would like to connect the display to a computer. But I do not know the circuit of connection. I ask to help me.
The display color CSTN, 96x64 (4096 colors), marks - WD-X0906VF-6CLWe - firms Wintek. <http://www.radiodream.ru/images/photos/1710327/09492240011241.jpg>
<http://www.radiodream.ru/images/photos/1710327/09597910011241.jpg>
In search datasheet I have not found this display, but have found similar WM-X0906V4-6CLWa, which so, 96x64 (4096 colors), on controller UC1682 (<http://www.gaw.ru/html.cgi/txt/lcd/lcm/Wintek/color/start.htm>)
UC1682 The controller:
Ultra Chip UC1682 - HIGH-VOLTAGE MIXED-SIGNAL IC
The name: UC1682
The manufacturer: Ultra Chip
Datasheet: UC1682.pdf (<http: // www.radioradar.net/files.html? *file=UC1682_UltraChip.pdf*fid=576507>)
The description: HIGH-VOLTAGE MIXED-SIGNAL IC
80 x 104RGB C-STN LCD Controller-Driver w/32-shade per dot, 12-bit per RGB (Dither 221K)
ES Specifications Revision 0.6
August 11, 2003
ULTRACHIP
The Coolest LCD Driver. Ever!!
UC1682
80x104RGB CSTN Controller-Driver
TABLE OF CONTENT
Revision 0.6
UC1682
UC1682
Single-Chip, Ultra-Low Power 80COM x 312SEG Matrix Passive Color LCD Controller-Driver
But how it can help me? I do not know....
I would like, what you though as that have helped me with this problem.
It is thankful in advance!
PostPosted: Sun May 06, 2007 10:43
:cry: People, help me please! :(
PostPosted: Sun May 06, 2007 20:14
I'm not familiar with the UC1682 but in the controller datasheet the pages 38-41 show examples of how to connect the controller. To verify which display connector pin is which controller pin you would need the display datasheet or then measure the signals with the display connected to a working phone.
As I'm not aware of PC software that would support this display you can connect the display pretty much any way you wish and then write the software to use that connection. The UC1682 controller supports parallel and serial interfaces but I'm not sure what pins are connected to the display connector. For some hints of using serial SPI connection the schematics presented for the 3310 display could be used:
http://forum.lcdinfo.com/viewtopic.php?t=474
But still you would need to write your own software.
PostPosted: Mon May 07, 2007 15:53
Henri
In this file: http://xmotors.wen.ru/files/Pic1.zip
contacts of a train of the display, to signatures of contacts are shown.
And as a part of the circuit of phone Mototola C156, the module of connection of the display. (too with signatures)
If you can help to connect as it(him) to LPT or COM port to a computer. I shall be very grateful.
Simply I the first races collide(face) with LCD the display, and I do not know as for what. Except for illumination LCD.
PostPosted: Sun Jul 13, 2008 12:07
Help me!
