It is currently Thu Oct 29, 2026 13:38
PostPosted: Sat May 08, 2004 3:31
I have CFAG12864B LCD. I'm trying to find some information regarding the intialization on LCD. The reset is pulled up to High always. Does this LCD requires special initialization?
Thanks,
PostPosted: Sat May 08, 2004 11:46
After reset you should send the DISPLAY ON command to both chips and also set the DISPLAY START LINE. Then setting both X and Y addresses and writing data should work.
Here's the commands: http://www.skippari.net/phpBB2/viewtopi ... =2836#2836
