It is currently Fri Jul 03, 2026 8:17
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
 Post subject: VB .NET Code translation
PostPosted: Wed Feb 19, 2003 23:54
This is the code that Henri posted few days ago:
The DLPortIO declarations with .NET
 Public Declare Function DlPortReadPortUchar Lib "dlportio.dll" ( _
           ByVal Port As Integer) As Byte
    Public Declare Function DlPortReadPortUshort Lib "dlportio.dll" ( _
            ByVal Port As Integer) As Short
    Public Declare Function DlPortReadPortUlong Lib "dlportio.dll" ( _
            ByVal Port As Integer) As Integer
    Public Declare Sub DlPortReadPortBufferUchar Lib "dlportio.dll" ( _
            ByVal Port As Integer, _
           <System.Runtime.InteropServices.MarshalAs (Runtime.InteropServices.UnmanagedType.AsAny)> ByVal Buffer As Object, _
            ByVal Count As Integer)
    Public Declare Sub DlPortReadPortBufferUshort Lib "dlportio.dll" ( _
            <System.Runtime.InteropServices.MarshalAs(Runtime.InteropServices.UnmanagedType.AsAny)> ByVal Buffer As Object, _
    Public Declare Sub DlPortReadPortBufferUlong Lib "dlportio.dll" ( _
    Public Declare Sub DlPortWritePortUchar Lib "dlportio.dll" ( _
            ByVal Value As Byte)
    Public Declare Sub DlPortWritePortUshort Lib "dlportio.dll" ( _
            ByVal Value As Short)
    Public Declare Sub DlPortWritePortUlong Lib "dlportio.dll" ( _
            ByVal Value As Integer)
    Public Declare Sub DlPortWritePortBufferUchar Lib "dlportio.dll" ( _
    Public Declare Sub DlPortWritePortBufferUshort Lib "dlportio.dll" ( _
    Public Declare Sub DlPortWritePortBufferUlong Lib "dlportio.dll" ( _
PostPosted: Wed Feb 19, 2003 23:56
    Public Sub WaitDisplayReady()
        Dim shtTemp As Short
        shtTemp = DlPortReadPortUshort(BASE_DADES + &H402)
        shtTemp = shtTemp And &H1F
        shtTemp = shtTemp Or &H20
        DlPortWritePortUshort(BASE_DADES + &H402, shtTemp)
        Do
            DlPortWritePortUshort(BASE_DADES + 2, &H20 + 4 + 2)
            DlPortWritePortUshort(BASE_DADES + 2, &H20 + 4 + 2 + 8)
            shtTemp = DlPortReadPortUshort(BASE_DADES)
        Loop While ((shtTemp And 3) <> 3)
        DlPortWritePortUshort(BASE_DADES + 2, 0)
    End Sub
PostPosted: Wed Feb 19, 2003 23:58
Public Sub WriteData(ByVal pvshtData As Short)
        DlPortWritePortUshort(BASE_DADES + 2, &HC)
        DlPortWritePortUshort(BASE_DADES + 2, &H8)
        DlPortWritePortUshort(BASE_DADES, pvshtData)
        DlPortWritePortUshort(BASE_DADES + 2, &H9)
    End Sub
    Public Sub WriteCtrl(ByVal pvshtCommand As Short)
        DlPortWritePortUshort(BASE_DADES + 2, &H4)
        DlPortWritePortUshort(BASE_DADES + 2, &H0)
        DlPortWritePortUshort(BASE_DADES, pvshtCommand)
        DlPortWritePortUshort(BASE_DADES + 2, &H1)
    End Sub
PostPosted: Thu Feb 20, 2003 0:00
Public Sub InitLCD()
        WriteData(T_BASE And &HFF)
        WriteData(RShiftLong(T_BASE, 8))
        WriteCtrl(&H40)
        WriteData(BYTES_PER_ROW)
        WriteData(0)
        WriteCtrl(&H41)
        WriteData(G_BASE And &HFF)
        WriteData(RShiftLong(G_BASE, 8))
        WriteCtrl(&H42)
        WriteData(0)
        WriteCtrl(&H43)
        WriteCtrl(&H80)
        WriteCtrl(&HA7)
        WriteData(&H0)
        WriteData(&H0)
        WriteCtrl(&H21)
        WriteCtrl(&H9D)
    End Sub
PostPosted: Thu Feb 20, 2003 0:03
Public Sub SetLCDXY(ByVal pvshtX As Short, _
                                ByVal pvshtY As Short)
        Dim shtAdreça As Short
        shtAdreça = T_BASE + (pvshtY * BYTES_PER_ROW) + pvshtX
        WriteData(shtAdreça And &HFF)
        WriteData(RShiftLong(shtAdreça, 8))
        WriteCtrl(&H24)
End Sub
Public Sub SetLCDCursor(ByVal pvshtX As Short, _
        WriteData(pvshtX)
        WriteData(pvshtY)
        WriteCtrl(&H21)
End Sub
Public Sub ClearLCDText()
        Dim shtCont As Short
        WriteCtrl(&H24)
        For shtCont = 0 To 640 - 1
            WriteData(0)
            WriteCtrl(&HC0)
        Next
End Sub
Public Sub ClearLCDGraph()
        WriteCtrl(&H24)
        For shtCont = 0 To NUM_PIXELS - 1 'shtCont < 5120
            WriteData(0)
            WriteCtrl(&HC0) 'write data and inc ptr
        Next
    End Sub
Public Sub SetLCDPixel(ByVal pvshtX As Short, _
        shtAdreça = G_BASE + (pvshtY * BYTES_PER_ROW) + (pvshtX / 6)
        WriteCtrl(&H24)
        WriteCtrl(&HF8 Or (5 - (pvshtX Mod 6)))
End Sub
Public Sub ClearLCDPixel(ByVal pvshtX As Short, _
        WriteCtrl(&H24)
        WriteCtrl(&HF0 Or (5 - (pvshtX Mod 6)))
End Sub
PostPosted: Thu Feb 20, 2003 0:04
Public Sub PrintLCDText(ByVal pvstrTexte As String)
    Dim bytLletra As Byte
    For shtCont = 0 To pvstrTexte.Length - 1
        bytLletra = AscW(pvstrTexte.Chars(shtCont)) - &H20
        If bytLletra < 0 Then bytLletra = 0
        WriteData(bytLletra)
        WriteCtrl(&HC0)
    Next
End Sub
PostPosted: Thu Feb 20, 2003 0:07
The constants for all this functions:
Public Const G_BASE As Short = &H300 'Graphic address
Public Const T_BASE As Short = &H0     'Text Address
Public Const BYTES_PER_ROW As Short = 40           'Bytes x row
Public Const BASE_DADES As Short = &H378   'Data port of LCD
Public Const NUM_PIXELS As Short = 5120
PostPosted: Thu Feb 20, 2003 10:12
Thanks for the code, Marc. :D
I'm sure it will be helpful.
 Post subject: True Type fonts
PostPosted: Thu Feb 20, 2003 13:21
How do you do to show True Type fonts ¿?
I tryed a lot of things, but I can't.
 Post subject: Re: True Type fonts
PostPosted: Thu Feb 20, 2003 13:32
I'm just drawing the font to a bitmap in the program and then drawing the bitmap to the screen. I think there should be something similar in .NET.
Is there some specific area where you would need help in this ?
PostPosted: Thu Feb 20, 2003 15:00
Ok, when you show bitmaps, the LCD draws the bitmap inmediatly ¿? or it delays ??
I will say if you draw a bitmap, it appears instantly (less than 0,1 seconds) in the LCD, or the image is showing slowly, (more than 0,5 secs.) ¿?
PostPosted: Thu Feb 20, 2003 15:13
That depends of the size of the bitmap you draw to the display. If you are writing one word using small font the bitmap could be 8x60 pixels so it's written very fast to the display.
I'm able to write fullscreen bitmaps to 240x128 T6963C display at 18 FPS, so you can't really notice even if you update the whole screen every time but of course writing full screens takes CPU time.
PostPosted: Thu Feb 20, 2003 15:27
How do you that ¿? Because i have a notable delay showing bitmaps.
PostPosted: Thu Feb 20, 2003 17:21
I have a buffer: unsigned char LCDBuffer[3840] that has the image and then the bytes are written to the LCD using auto write mode.
Could you post some of your bitmap code so maybe I could tell how to make it faster ? How are you storing the bitmap and how do you read the bitmap and how do you write it to the display ?
PostPosted: Thu Feb 20, 2003 22:49
Hi Henri.
I use this code for display a botmap that is in a PictureBox control :
Public Sub sbrDibuixaLCDBMP(picPicBox As PictureBox, _
                            intX As Integer, _
                            intY As Integer)
   Dim intAddr As Integer
   Dim intI As Integer
   Dim intJ As Integer
   Dim intK As Integer
   Dim lngLCDValue As Integer
   Dim intTmp As Integer
   For intI = 0 To 127
      intAddr = G_BASE + ((intY + intI) * BYTES_PER_ROW) + (intX / 6)
      Call sbrEscriuData(intAddr And 255)
      Call sbrEscriuData(fnclngDesplaçarBitsDreta(intAddr, 8))
      Call sbrEscriuCtrl(36)
      Call sbrEscriuCtrl(176) 'auto write mode on
      For intJ = 0 To 127
         lngLCDValue = 0
         'build the byte to send to display
         For intK = 0 To 4 'add all bits except last one
            If picPicBox.Point(6 * intJ + intK, intI) <> 0 Then
               intTmp = 0
            Else
               intTmp = 1
            End If
            lngLCDValue = lngLCDValue Or intTmp
            lngLCDValue = fnclngDesplaçarBitsEsquerra(lngLCDValue, 1)
         Next intK
         If picPicBox.Point(6 * intJ + 5, intI) <> 0 Then
            intTmp = 0
         Else
            intTmp = 1
         End If
         lngLCDValue = lngLCDValue Or intTmp 'addlast bit to byte
         Call sbrEscriuData(lngLCDValue)
      Next intJ
      Call sbrEscriuCtrl(178) 'auto write mode off
   Next intI
End Sub
I think that this code can be optimized, but i don't know how to solve the delay problem.
