It is currently Mon Jul 27, 2026 5:00
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Tue Apr 08, 2003 3:50
Hello
i´am going to buy a g lcd , most possible cheap.
Now my question: do work the follow lcd´s with LCDinfo
1. 160 X 128 dot LCD Optrex DMF5003NF-FW
2. 240 x 64 LCD AND 4021ST-EO
greetz from germany
PostPosted: Tue Apr 08, 2003 4:10
Hmmm i´ve searched the net and think the controller of the optrex lcd is called 6963c-0101.
maybe this help you to answer my question
thx
PostPosted: Tue Apr 08, 2003 18:47
If it has a T6963C controller it should work with LCDInfo. 0.3.2 version doesn't support all sizes but the next version has more support.
Do you know what controller is in the other display ?
PostPosted: Thu Apr 10, 2003 4:20
fist thx for answering -
but i am still searching for a compatibel and cheap lcd.
in fact i don´t understand finnish but while searching i found this links on forum:
http://earthlcd.com/character.htm
http://www.timeline-inc.com/lcd.html <-- upper lcd i found there
http://www.evotron.com/
http://www.allelectronics.com/cgi-bin/c ... type=store
http://www.meci.com/
wow god prices i think
so could you tell me wich ones are compatible to lcdinfo - and i bring it to work
hmm and what is with a inverter i would need , can i take selfmade one
or were to buy
or did someone have alredy bought an lcd from this shops and can tell something about
the lcd should be deliverd to germany and when i buy o wrong one - :oops:
thx
PostPosted: Thu Apr 10, 2003 8:45
Not all of those links tell what controller is in the lcd but I think that Optrex DMF5000 series has T6963C controllers. Also AND 4021ST-EO is probably a 240x64 display with T6963C controller. Sharp LM24014H also has a T6963C controller. Meci also had couple 240x64 T6963C displays.
I'm sure it would be easier if you found a display with LED backlight so you don't have to use inverters.
You can make inverter yourself but it would probably be easier to buy one. I don't have any displays that would use inverters so I haven't looked for places to get them either.
PostPosted: Fri Apr 25, 2003 1:37
the dmf5003 is the same as mine and the software from henri is working good.. henri made a version for me with the right sizes..i have this version stil ...
PostPosted: Sun May 04, 2003 4:03
ok now i ordered those display from optrex.
oh men that was a torture.
first they got my mail, then not , then i have to call to them
with my broken english.
but now....juhuu
matchless could you send me a simple plan you have build the display
so it would be easyer for me.
and henri thank u too for all needed infos.
oh maybe i should register, :arrow: GUEST :oops:
PostPosted: Thu Jun 26, 2003 4:27
Hello
now I got the Optrex DMF5003NF-FW
and I´found a "Lötanleitung" 8O
but how I can get -21Volt for the lcd power supply
ATX is only -12 Volt possible
Matchless how do you did it.
help needed please
thx
greetz
PostPosted: Thu Jun 26, 2003 13:53
i got the neg. voltage out of a LT1051 chip.give me you mail adres and ik send you the schematics..
PostPosted: Thu Jun 26, 2003 15:19
elektro-schmiede@web.de
thank u
PostPosted: Fri Jun 27, 2003 0:10
forgott login
so
PostPosted: Wed Sep 01, 2004 13:09
Can you send the schematics to jrpcosta.at.hotmail.com ?
tanxs,
raul costa
PostPosted: Wed Sep 01, 2004 13:28
i will look this week.the schematic is on a cd but wich one 8O
PostPosted: Wed Sep 01, 2004 19:13
Tanxs you are a live saver.
I know very little about electronics, and i don't knowthe pinout (well i know the pinout, but not the relaction to the parallel port pinout).
Tanxs for the help.
Raul Costa
PostPosted: Sat Sep 04, 2004 21:20
i have not found the schematic at the moment but i looked on the net what i've used.next week i will reverse engineer the lcd i have.but for the beginningyou can make this schematic:
this is the schematic i used.also the data 0 to 7 has to be connected to pin 2 -> 8.
that's 12 to 19 on the optrex.pin 11 from the optrex need to be pulled up to 5 volts with a resistor.a pushbutton must be also connected with this pin.so if you push the button the voltage is being drawn down to ground.next week a schematic for you..
