It is currently Tue Nov 03, 2026 3:37
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: one little question
PostPosted: Fri Jan 30, 2004 20:27
hi there,
i recently bought a 128x64 GLCD with the KS0108 Controller and of course I use LCDInfo :-). My problem: in some cases it happens, that the display shows letters or numbers, where no ones should be. What I mean is, i.e i'm listening to a winamp track called "Subterranean", then the track is over and i wanna switch to a track called "Scorn", then have the problem, that the display shows " Scornrranean". I hope you have understood.
PostPosted: Tue Feb 03, 2004 13:22
This is a known problem. I suggest you use 0.6 version of LCDInfo which you can find in the 0.6 section of this forum (bottom at the from forum front page).
