It is currently Thu Oct 29, 2026 11:20
Post new topic Reply to topic  [ 174 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 12  Next
 Post subject: IC PROBLEMS!!!
PostPosted: Sun Mar 28, 2004 2:06
Hi, again!
I have a lousy problem with my IC (dm7445n, right)... it only has 16 connectors 8O 8 in each side!
Cheking the DarkElf's pic, I realize that I can't connect some cables.
Can anybody explain +/- what can I do with this???? :?
PostPosted: Mon Mar 29, 2004 9:41
thnak you very much henri....
i will read the pdf and try the things...on LCD...
thanks 1's again....
regards....
sada....!!!!!
With Warm Regards From....!!!
Sada...!!!!
 Post subject: Re: IC PROBLEMS!!!
PostPosted: Mon Mar 29, 2004 16:20
~sCooT~ wrote:
Hi, again!
I have a lousy problem with my IC (dm7445n, right)... it only has 16 connectors 8 in each side!
DM7445N seems to be a "BCD-to-Decimal Decoder". What you need is a "Low Voltage Bidirectional Transceiver with 5V Tolerant Inputs" eg. 74LCX245 or 74LVC245.
I don't know why in DarkElf's picture the IC is marked as 7445 instead of 74xx245. 74LCX245 and 74LVC245 are 20 pin ICs that you can usually find in a SOIC package. For description of the circuit and datasheet links for the ICs you can check the first page.
PostPosted: Tue Mar 30, 2004 12:27
Henri wrote:
~sCooT~ wrote:
Hi, again!
Thanks Henri! 8) I'll see what I can do!
Henri wrote:
~sCooT~ wrote:
Hi, again!
PostPosted: Sat Apr 03, 2004 11:45
I've connected my nokia lcd in the wrong way :(
I pluged it the wrong side so pin 1 at pin 8, pin 2 at pin 7 and so on...
It doesn't seem to work anymore. do you think it is broken or the problem could be somewhere else :?:
[EDIT] ok no problem it's working now :oops:
PostPosted: Sat Apr 03, 2004 13:32
Henri wrote:
Here is some data for 128x128 controllers used in Nokia color displays:
http://www.hantronix.com/down/S1D15G00_REV1_0.pdf
http://www.semiconductors.philips.com/p ... 2DA_1.html
There are two different display types that look almost same but have different controllers. I have one of each but as I wrote earlier I haven't yet started working on those.
LOL, you too eh :D
Anyways, I'm trying to get the Philips version to work. I do have the Epson version aswell, but there seem to be much problems with it when it comes to different voltages and the display contrast.
Besides that, the Epson one has no easy to solder contacts, the Philips one does.
Also documentation is a little at the sucking side for the Epson, which is another reason I'm trying to avoid it. The Philips version has a very nice datasheet, so this one is not a problem :)
Might be a good idea to start a new topic about this to keep the b/w talk separated from the colour discussion.
Creator of LiQuiD-MP3
PostPosted: Sat Apr 03, 2004 15:14
Jep, me too :D
I was also planning to start with the Philips and later with the Epson. You pretty much just said the reasons for going with Philips. ;)
I just made a new topic where all further color lcd discussion can be directed: http://www.skippari.net/phpBB2/viewtopic.php?t=586
PostPosted: Sun Apr 04, 2004 12:21
Mhh has anyone infos about these lcd display under linux
i think i can make it for my m3 pc but i am sure, id doesn'T give lcdinfo 4 linux :(
PostPosted: Wed Apr 07, 2004 22:05
Hello!
I ll be inspired by connect display 3310 to lpt, i go to IC shop and ask for display 3310,i bought somemthin like that
[img]http://www.volya.by.ru\lcd\img_0023.jpg[/img]
i ll made schematic with "74 soic 245 3.3v tolerant to 5v"
and connect all to lpt.
So wheres on this display pin 1 ? What is it , like ???PIN9???
What is REAL name of this display {for 3310?made in china?}
If i power this lcd by 3.3 v and not connect all other pins : then lcd show somethin for i KNOW : i connect other pins and its work?
What software support this lcd-lpt?
beta of lcd info?
Sorry for my bad Inglish 8)
PostPosted: Thu Apr 08, 2004 15:27
For the pin positions check this post:
http://www.skippari.net/phpBB2/viewtopi ... =2527#2527
I don't know what's the real name or model for this display. It's some custom display made for Nokia specifically.
I don't think you can see anything on the display until it's properly initialized.
LCDInfo 0.6 supports this display using the connection from the first page of this thread.
 Post subject: 6310 and 6210 lcd...
PostPosted: Mon Apr 12, 2004 13:05
hi henri...
can you tell us which controller is present in 6310 and 6210and mobile phone lcd's...
thanks in advance....
Sada...!!!!
PostPosted: Thu Apr 15, 2004 11:11
I don't know what is the controller in 6310 or 6210 but it could be something similar to PCD8544. What is the screen resolution in these displays ?
3410 for example has a 96x65 screen that works with the same interface and commands.
 Post subject: screen resolution
PostPosted: Fri Apr 16, 2004 9:55
hello henri...
thanx for the reply...
hey the screen resolution for 6210 is 96 * 60
and the screen resolution for 6310 is 96 *65...
but still i dont know about the controller.....
is it possible for you to tell me this information... :roll:
or can you tell me from where i get this information....
because i searched on net a lot...but disappointed everytime..
cause i dint find anywhere this kind of information....
any ways ....!!!!
thanks in advance...!!!
Sada...!!!!
 Post subject: hi again with 6310
PostPosted: Fri Apr 16, 2004 17:13
hi henri..
OM6208_2 65 x 96 pixels matrix grey-scale LCD driver
is this is the controller used in 6310.....and 6210
what do you think....
waiting for your reply...
Sada...!!!!
