It is currently Wed Nov 04, 2026 15:46
PostPosted: Mon Jun 07, 2004 17:46
I had a lot of LCD´s (most of them HD44780) which I can´t turn on the backlight, I can´t find any datasheet. I put 5V on the backlight pins but no responce. Is there any sort of inverter I can use in order to turn it on?. Sorry for my english, thanks
PostPosted: Wed Jun 09, 2004 15:55
Have you tried with both polarities ? Some displays have an EL sheet as the backlight and need EL inverter.
PostPosted: Wed Jun 09, 2004 16:38
were could i find the schematic for building the EL inverter?
PostPosted: Thu Jun 10, 2004 22:02
Goto photoshop (camera) and ask used onetimeuse cameras and took that flash from it.
Remove condersator, flash, that funny lamp, diode.
Now you got 120v ac that works from 1.5volts and power el-stuff.
At least el-wire works with that
