It is currently Tue Sep 22, 2026 11:23
PostPosted: Thu Jul 22, 2004 16:01
I've looked and searched, but I can't seem to find information inhere about it, but does anyone has any experience with this display?
Manufacturer: Winstar
Type: Graphic 240*64dots
Graphic(?): Toshiba T6963C
My plan is to connect is to the parallelport and display whatever stuff I want... haven't desided on which program to use yet (if I can find one that supports this display).
But my question is, how do I wire it up? LCD <-> DSUB25
I'm not so much into what goes where yet, but here's some links to info about the display...
http://www.winstar.com.tw/mysql/chips/WG24064A.PDF
http://www.electrokorea.com/24064AYYBVLB.doc
I'm looking forward to any help I can get :D
Thanks!
 Post subject: LCD manufacturer
PostPosted: Thu Jul 29, 2004 5:03
Pls go to Wincom
http://www.wincomlcd.com
you can get full technical support, even program.
Regards,
PostPosted: Thu Jul 29, 2004 11:13
My plan is to connect is to the parallelport and display whatever stuff I want... haven't desided on which program to use yet (if I can find one that supports this display).But my question is, how do I wire it up? LCD <-> DSUB25
Thanks!
try this
I'm wire WG240128A, like your LCD. Any question on my e-mail
PostPosted: Thu Jul 29, 2004 11:42
Pin No. Symbol  Level   Description
1       FG      -       Frame ground ( Connected to bezel )
2       Vss     -       GND
3       Vdd     -       Power supply ( +5 V )
4       Vo      -       Power supply for LCD driver
5       /WR     L       Data write. Write data into T6963C when WR = L
6       /RD     L       Data read. Read data from T6963C when RD = L
7       /CE     L       L : Chip enable
8       C/D     H / L   WR=L , C/D=H : Command Write  C/D=L: Data write RD=L , C/D=H : Status Read  C/D=L: Data read
9       Vee     -       Negative voltage –10V output
10      /RESET  H / L   H : Normal ; L : Initialize T6963C
11      DB0     H / L   Data bus line
12      DB1     H / L   Data bus line
13      DB2     H / L   Data bus line
14      DB3     H / L   Data bus line
15      DB4     H / L   Data bus line
16      DB5     H / L   Data bus line
17      DB6     H / L   Data bus line
18      DB7     H / L   Data bus line
19      FS      H / L   Pins for selection of font; H : 6 * 8 , L : 8 * 8
20      N.C     -       No connection
This seems to match the pinout here http://www.skippari.net/lcd/t6963c_schem.html except that this Winstar display has negative voltage output in pin 9 so there's no need for external negative voltage.
You can look into this pdf that Cryofast showed to see how to connect the 10K potentiometer to adjust the contrast.
http://www.turbokeu.com/mycomputer/glcd/glcd.pdf
PostPosted: Wed Aug 11, 2004 20:13
Thanx, this should be sufficiant to get me working ;)
Users browsing this forum: No registered users and 606 guests
