It is currently Fri Sep 18, 2026 8:46
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 16, 2004 21:16
how are you doing plugin m program or what :S . i want that i can show lika stats in cs if that is possible ? :lol:
PostPosted: Wed Mar 24, 2004 21:46
To make LCDInfo plugins you need to do some C++ programming. Are you familiar with that ? CS stats are not yet supported but if anyone would like to make a plugin for that I'd be happy to give help and advice.
PostPosted: Sat Aug 14, 2004 14:29
I don’t understand the histo and bars.
or
Here are Pictures from the histo (sorry for the bad quality), should it be look like that?
PostPosted: Tue Aug 17, 2004 21:40
I don't think it should look like that. I've never used this plugin myself so I can't say from experience but that doesn't look correct.
Building the plugin with the newest SDK might help but I don't have the sources. Also DarkElf reported earlier in this forum that he had lost all his files so the sources might not exist anymore. I'll send him mail and ask about it.
PostPosted: Fri Sep 10, 2004 19:34
Is there some support for kademlia yet?
PostPosted: Fri Sep 17, 2004 16:38
Hmm, what is kademlia ? Quick search seems to suggest it's something about emule. I suppose it's not yet supported. And the problem with this plugin by darkelf seems to be that there is no source code anymore and the only thing left of the plugin is the dll from this thread.
So it would be necessary to start again a new plugin and maybe keep the sources in safe place this time. :)
It shouldnt' be very difficult as the method used is explained in this thread also.
PostPosted: Sat Sep 18, 2004 22:10
Kademlia is a P2P network devellopped by the emule team, to eventually replace the ED2K network.
But when i look at the onlinesig.dat file is see there's no information displayed about kademlia.
PostPosted: Wed Oct 06, 2004 16:32
same as timeinfo plugin need to be rebuild with build 18 sdk ^^
£+µ :?
PostPosted: Wed Oct 06, 2004 16:53
and same bug as D3s3rt with bar and other graphic stuff.
£+µ :(
PostPosted: Wed Oct 06, 2004 17:12
The problem with rebuilding it is that the source code for it might not exist anymore. I'm not yet 100% certain of what the situation is.
PostPosted: Wed Oct 06, 2004 17:37
Just got the confirmation that the source code doesn't exist anymore. So looks like it should be done again...
