It is currently Wed Oct 28, 2026 1:05
Post new topic Reply to topic  [ 288 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 20  Next
 Post subject: Sagem my-v55
PostPosted: Sun Aug 15, 2004 11:10
Ik heb ff een vraag wat dachten jullie van een sagem my-v55 scherm als lcd?
65000 kleuren :lol:
Ik heb namelijk zelf zo'n toestel en wil maar al te graag dat scherm in me pc dauwe maar HOE?
En btw ik heb ook het scherm van een sagem-Myx2 liggen.
Heeft iemand tips tutorials schema's?
THX
http://www.magboss.aza.pl/catalog/produ ... cts_id=350
DIT is het scherm van een my-x5 maar het lijkt wel verdomd veel op de my-x2
PostPosted: Tue Nov 09, 2004 13:25
hi, im looking at using one of these lcds in a pc case mod, as a "case badge". i would, for now, like to display either a chosen picture, or an animated gif. is there any new updates to this current info? with the given schematic, what pins do i wire to the usb tx and rx?what coding do you use to achieve this? any help would be appreciated.
PostPosted: Thu Nov 25, 2004 23:20
hi, i am one of those unlucky people that have the Epson S1D15G00 LCD
it is original from nokia 3100, so how do we re-wire that lcd to control it
over lpt or any other way, how do i just display something on it?
 Post subject: Nokia Color Lcd
PostPosted: Thu Dec 09, 2004 4:41
Hi all,
Magboss webstore has Nokia LCD from Philips controller.
http://www.magboss.pl/product_info.php? ... cts_id=638
18,00 Euros.
Best Regard
---=[ Junior ]=---
www.lcdmania.net
 Post subject: the color lcd
PostPosted: Wed Jan 05, 2005 17:15
I'm trying to use an pic18f452 to control this 6610 display with a pcf8833 and so far I can't get the display to do anything.
So my question is: Is there anyone out there wo had any successes in interfacing a pic18 or pic16 to this display. Any code examples would be very usefull.
Also I don't have quick access to those chips that u can use to get interface voltage from 5v to 3.3v So i used simple resitor voltage dividers. I have seen it done before but I'm not sure about how good this solution realy is. Maybe I should use zenerdiodes.
As I side note: I also got my display from magboss. They ask half the price the ask here in the netherlands and you can specifically ask for the philips based ones. I used wired money transfer as the payment options and it wat delivered within five days
bart
PostPosted: Thu Jan 06, 2005 3:08
See link:
http://www.apetech.de/nokia6100.php
There are library in C for Nokia 6100 LCD.
Junior
---=[ Junior ]=---
www.lcdmania.net
PostPosted: Thu Jan 06, 2005 12:13
Thank you for the suggestion lcdmania but I already found that link and altough is is in C (lattest version only in asm). I'm to unfamiliar with the avr to understand from it what I'm doing wrong. It is even possible that my hardware setup is at fault somewhere so I realy need a known working example.
bart
PostPosted: Sun Jan 09, 2005 17:37
I'm making progres!
I removed my resistor dividers and changed them to a diode resistor combination that seems to work. Next on my list are bus tranceivers. Als I lowered the voltage of the display to 2.7v. This gave better colors. The problem I have left are thes dancing black lines accros the screen, like looking at a bad broadcast. They don't change the ram data though so it looks like I'm getting some interference from a power supply or so er maybe the air. There is a lot of blank coper wire in my testbed. But if anybody got some other experience that he got ride of a similar effect don't hessitate to share!
bart
PostPosted: Fri Jan 14, 2005 18:56
hi
I want inc for bascom for avr
 Post subject: convert bmp 256 color
PostPosted: Sat Feb 05, 2005 5:02
I want write pictures.
What program i need to use to convert bmp files 256 color to format to LCD phillips (3:3:2) and compile to ASM.
You can help-me
Sorry my english.
PostPosted: Sat Feb 12, 2005 12:27
Probably you would need to write this utility yourself. Haven't seen these around.
PostPosted: Mon Feb 14, 2005 18:45
Henri,
The shijf write the picture below.
what software he used to write this ?
I need convert it.
 Post subject: Re: Nokia Color Lcd
PostPosted: Mon Feb 14, 2005 21:12
lcdmania wrote:
Hi all,
18,00 Euros.
Best Regard
Im looking to buy two of these graphics lcd.
Im just wondering if this description i correct
LCD Display Nokia 3100/6100 - Philips
A lot here is talkong about the 6610 , not the 6100.
Are the 6100 display the same as described here.
/Bingo
PostPosted: Wed Feb 16, 2005 0:53
/Bingo
Yes I think the "LCD Display Nokia 3100/6100 - Philips (original)" is the same display with Philips controller as discussed in this topic.
PostPosted: Wed Feb 16, 2005 0:55
gafar wrote:
Henri,
I need convert it.
He probably wrote his own and it I suppose it was just some test stuff not ready for public eyes. I don't know.
It's not that difficult to write that kind conversion yourself. And it's good practice in understanding how the colors work in these displays.
