It is currently Sat Aug 22, 2026 11:01
 Post subject: nokia 7210 lcd
PostPosted: Sun Nov 14, 2004 5:11
hi, im looking at using one of these lcds in a pc case mod, as a "case badge". i would, for now, like to display either a chosen picture, or an animated gif. is there any new info apart from the stuff i the nokia color lcds thread? with the given schematic, what pins do i wire to the usb tx and rx?what coding do you use to achieve this? any help would be appreciated.
PostPosted: Sun Nov 14, 2004 19:13
I suppose no further development has been going on, at least not for me.
The connection used has been this: http://www.schijf.org/colourlcd/usb_colour_lcd.gif
So there has been the FTDI FT245BM IC between usb and the display. Then to wiggle the lcd lines the FTDI bit bang features have been used.
For connecting the FT245BM chip to usb have a look into the datasheet: http://www.ftdichip.com/Documents/ds232bv16.pdf
Then there are FT232BM Application Schematics:
http://www.ftdichip.com/Files/232sch20.zip
FT232BM Designers Guide:
http://www.ftdichip.com/Documents/dg232v20.pdf
FT232BM / FT245BM Bit Bang Mode:
http://www.ftdichip.com/Documents/AN232-01_BitBang.pdf
Other application notes:
http://www.ftdichip.com/FTApp.htm
PostPosted: Mon Nov 15, 2004 8:51
ok, thanks for all the info, i will see how i go piecing all this together. cant wait til more development is done on it.
