It is currently Thu Nov 05, 2026 1:35
PostPosted: Mon Feb 21, 2005 7:24
I was thinking of purchasing one of these color displays (SONY ACX705AKM). They are selling cheap and are color. Tho I know LCDInfo has no driver for this gLCD, I do know some of you out there are experimenters and might be able to give me some guidance/advice...or even if it is worth the hassle.
Here is a link to the spec sheet.
Regards,
Iridium
PostPosted: Tue Feb 22, 2005 16:36
Well what do you want to use it for? It'll need a new kind of controller and also software needs to be written for it.
A higher SED or FPGA should be able to drive it.
PostPosted: Tue Feb 22, 2005 19:11
Yes, what would you like to do with the display is important question here. Are we talking about connecting it to PC or some other device ? Do you have some programming experience and willing to write your own software here.
I'm sure it can be used but if this display is good choice for your needs I don't know. Like coorz said it will need some additional hardware to drive it in most cases.
PostPosted: Wed Feb 23, 2005 2:07
I'd just be hooking it up to the PC. My only programming skills are in VB and that is very limited. It looks as tho I should keep my $20 in my pocket and pass on the LCD.
I do make my own printed circuit boards for various projects (mostly LCD interface and support circuitry). But programming a driver would probably be a bit rough for me. :oops:
Thanks for the feedback, I do appreciate it! :)
Regards,
Iridium
Users browsing this forum: Google [Bot] and 7 guests
