It is currently Tue Nov 24, 2026 17:13
PostPosted: Sun Jan 12, 2003 18:31
hi
my display T6963c Toshiba controller 128x128 works with LCDinfo 0.3.1
i installed the new version LCDinfo v 0.3.2 added the screen ini 128x128_t6963c.ini and the folder 128x128_t6963c_images
after that i opened lcdinfo_config.exe and set the preferences to
my display and loaded the screen which worked on version 0.3.1
but the displays shows only shit
the test.ini also didn´t work
pls help me
PostPosted: Sun Jan 12, 2003 18:44
maybe you chose the wrong wiring?
for me 0.3.2 works better than 0.3.1
PostPosted: Sun Jan 12, 2003 20:48
Like con told, wrong wiring setting might be a good candidate for the problem.
Are you still having problems ?
