It is currently Wed Oct 07, 2026 16:36
PostPosted: Wed Jun 22, 2005 17:43
I'm having problems with controlling a T6963C through LPT port with Visual Basic 6. For some reasons, I don't get it to work (I made my program set a pixel after init, but nothing shows up). I don't know how. Could someone look at my code? It's made for Tweakers.net Wiring. Other programs like LCDInfo and LCDHype works perfect. It's a 128x64 display Clover Electronics Dispaly (Atleast I thought).
Also some questions witch I could find any answer on: The datasheet from the T6963C says you have to set some control lines high or low, but do you need to set them all at the same time? If not, do you have to first set the first high/low, then the first + second high/low etc? And does a SetPixel function directly works? And how do you set the LPT contro\data lines before initializing LCD etc (HALT\RESET piece from datasheet didn't answerd my question)
I hope someone can halp me,
Thanks in advance,
Bas St.
In a Module:
Public Declare Function DlPortReadPortUchar Lib "dlportio.dll" (ByVal Port As Long) As Byte
Public Declare Function DlPortReadPortUshort Lib "dlportio.dll" (ByVal Port As Long) As Integer
Public Declare Function DlPortReadPortUlong Lib "dlportio.dll" (ByVal Port As Long) As Long
Public Declare Sub DlPortReadPortBufferUchar Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub DlPortReadPortBufferUshort Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub DlPortReadPortBufferUlong Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub DlPortWritePortUchar Lib "dlportio.dll" (ByVal Port As Long, ByVal Value As Byte)
Public Declare Sub DlPortWritePortUshort Lib "dlportio.dll" (ByVal Port As Long, ByVal Value As Integer)
Public Declare Sub DlPortWritePortUlong Lib "dlportio.dll" (ByVal Port As Long, ByVal Value As Long)
Public Declare Sub DlPortWritePortBufferUchar Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub DlPortWritePortBufferUshort Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub DlPortWritePortBufferUlong Lib "dlportio.dll" (ByVal Port As Long, Buffer As Any, ByVal Count As Long)
Public Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Public Declare Function GetTickCount Lib "kernel32" () As Long
Private LCD_Control_Address As Long
Private LCD_Data_Address As Long
Private LCD_LPT_Port As Long
Private LCD_Graphic_Address As Long
Private LCD_Text_Address As Long
Private LCD_Bytes_Per_Row As Integer
Private OnBits(0 To 31) As Long
Public Function LShiftLong(ByVal Value As Long, ByVal Shift As Integer) As Long
    MakeOnBits
    If (Value And (2 ^ (31 - Shift))) Then GoTo OverFlow
    LShiftLong = ((Value And OnBits(31 - Shift)) * (2 ^ Shift))
    Exit Function
OverFlow:
    LShiftLong = ((Value And OnBits(31 - (Shift + 1))) * (2 ^ (Shift))) Or &H80000000
End Function
Public Function RShiftLong(ByVal Value As Long, ByVal Shift As Integer) As Long
Dim lngHi As Long
    MakeOnBits
    If (Value And &H80000000) Then lngHi = &H40000000
    RShiftLong = (Value And &H7FFFFFFE) \ (2 ^ Shift)
    RShiftLong = (RShiftLong Or (lngHi \ (2 ^ (Shift - 1))))
End Function
Private Sub MakeOnBits()
Dim intJ As Integer, intV As Long
    For intJ = 0 To 30
        intV = intV + (2 ^ intJ)
        OnBits(intJ) = intV
    Next intJ
    OnBits(intJ) = intV + &H80000000
End Sub
Public Function LCDInit(lcdSpecs As lcdInfo, Optional lngLPTAddress As Long = &H378) As Boolean
'On Error GoTo Error
    LCD_LPT_Port = lngLPTAddress
    LCD_Data_Address = LCD_LPT_Port + 0
    LCD_Control_Address = LCD_LPT_Port + 2
    LCD_Graphic_Address = &H300
    LCD_Text_Address = &H0
    LCD_Width = lcdSpecs.lcdWidth
    LCD_Height = lcdSpecs.lcdHeight
    LCD_FontHeight = lcdSpecs.lcdFontHeight
    LCD_FontWidth = lcdSpecs.lcdFontWidth
    'LCD_Bytes_Per_Row = lcdSpecs.lcdWidth \ lcdSpecs.lcdFontWidth
    LCD_Bytes_Per_Row = 40
    LCDInit = LCDDriver
    Exit Function
Error:
    LCDInit = False
End Function
Public Function LCDDriver() As Boolean
    LCDWriteData LCD_Text_Address And &HFF ' Text Address
    LCDWriteData RShiftLong(LCD_Text_Address, 8)
    LCDWriteControl &H40
    LCDWriteData LCD_Bytes_Per_Row ' Bytes per Row
    LCDWriteData &H0
    LCDWriteControl &H41
    LCDWriteData LCD_Graphic_Address And &HFF  ' Graphics Address
    LCDWriteData RShiftLong(LCD_Graphic_Address, 8)
    LCDWriteControl &H42
    LCDWriteData &H0
    LCDWriteControl &H43
    LCDWriteControl &H80 ' Internal CG-Rom and Or Mode
    LCDWriteControl &HA7 ' 8 Line Cursor
    LCDWriteData &H0
    LCDWriteData &H0
    LCDWriteControl &H21 ' Cursor at 0,0 (x,y)
    LCDWriteControl &H9D ' Display Ready
    LCDDriver = True
    Exit Function
Error:
    LCDDriver = False
End Function
Public Function LCDWriteControl(lngData As Integer) As Boolean
    Call DlPortWritePortUshort(LCD_Data_Address, lngData)
    Call DlPortWritePortUshort(LCD_Control_Address, 0) 'CDHI
    Call DlPortWritePortUshort(LCD_Control_Address, 0) 'CDHI | WRLO | RDHI
    Call DlPortWritePortUshort(LCD_Control_Address, 1) 'CDHI | WRLO | RDHI | CELO
    Call DlPortWritePortUshort(LCD_Control_Address, 0) 'CDHI | WRLO | RDHI | CEHI
    Call DlPortWritePortUshort(LCD_Control_Address, 8) 'CDLO
    LCDWriteControl = True
    Exit Function
Error:
    LCDWriteControl = False
End Function
Public Function LCDWriteData(lngData As Integer) As Boolean
    Call DlPortWritePortUshort(LCD_Control_Address, 8) 'CDLO | WRLO | RDHI
    Call DlPortWritePortUshort(LCD_Control_Address, 9)  'CDLO | WRLO | RDHI | CELO
    Call DlPortWritePortUshort(LCD_Control_Address, 8)  'CDLO | WRLO | RDHI | CEHI
    LCDWriteData = True
    Exit Function
Error:
    LCDWriteData = False
End Function
Public Function LCDSetPixel(intX As Integer, intY As Integer) As Boolean
Dim intAddress As Long
    intAddress = LCD_Graphic_Address + (intY * LCD_Bytes_Per_Row) + (intX / 6)
    LCDWriteData intAddress And &HFF
    LCDWriteData RShiftLong(intAddress, 8)
    LCDWriteControl &H24
    LCDWriteControl (&HF8 Or (5 - (intX Mod 6)))
    LCDSetPixel = True
    Exit Function
Error:
    LCDSetPixel = False
End Function
In a Form:
Private Sub Form_Load()
Dim lcdSpec As lcdInfo
Dim intTemp As Integer
    With lcdSpec
        .lcdWidth = 128
        .lcdHeight = 64
        .lcdFontHeight = 8
        .lcdFontWidth = 6
    End With
    LCDInit lcdSpec, &H378
    For intTemp = 10 To 100
        LCDSetPixel intTemp, 10
    Next intTemp
End Sub
(Code based on code from this topic). I'm not a n00b, so I can interp C code if one of you has a working piece of code.
No need to place a Sig :)
2 x a 4x20 Text LCD
1 x a 128x128 Graphic LCD
1 x a 128x64 Graphic LCD
PostPosted: Sat Jun 25, 2005 14:28
Anyone?
2 x a 4x20 Text LCD
PostPosted: Wed Jun 29, 2005 18:42
Really no one? I really need some help, because I don't know other forums/sites where I could ask this.. :(
2 x a 4x20 Text LCD
PostPosted: Wed Jun 29, 2005 20:08
I'm sorry i can't help you with that as i'm not skilled in that area. Wait till Henri shows up, he should know :)
PostPosted: Mon Jul 04, 2005 13:23
Ok I will have a look into this. Just that as it's VB code and I haven't used it for anything than some necessary interface work it just looks like mess with no good structure to me ;) so I need to concentrate more and I don't have the time for it just now.
PostPosted: Mon Jul 04, 2005 16:13
Okey :) Take time for it ;) About the mess, well yeah, code is modified from original plan, because it didn't workedin first case, so my dad said to make it more easier, so some things will lead to nothing :)
2 x a 4x20 Text LCD
Users browsing this forum: No registered users and 616 guests
