It is currently Sat Jun 27, 2026 21:32
PostPosted: Sun Aug 07, 2005 20:15
Hi all
Ive got one of Henri's 320x240 displays and so far untill earlier im well happy with it
Ive got a big problem with the display, all was working fine with the
display untill earlier when i was in the config section of the driver and ive
tryed everything to get the display wotking again, all im getting is lines
accross the screen, ive even tryed default install of lcdinfo but nothing im
worried that ive damaged the controller chip any, do my settings look right
Thanks for anyones help in advance
Cheers
PostPosted: Sun Aug 07, 2005 22:11
Try with a freq of 10mhz and your res is at 128x64 should be 320x240 , and check your wiring ,
mine is wired for the info preset , which is different to your wiring above.
Hope you get it going again :D
PostPosted: Mon Aug 08, 2005 0:17
all done and working it was the XTAL needed setting to 10 mhz
heres some pics of the display and frame i got for it
Cheers Cougs
