It is currently Tue Nov 17, 2026 0:05
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Aug 23, 2005 12:56
Thx Michael and Zee.
If I understand right, after setting a page you have 8 vertical pixel to write, which explains the 8bits you send from the parallelport. And you have to write something, 8bits at once, no matter if it is zeros or ones.
Knowing this makes it harder to make a plot-function, because the function bepends what u write to the LCD. example: write 0x04 on position (0,0) leads to a dot on (0,1) on the LCD.
One solution I think of is to have a dynamic write-value
and plz e-mail me, I like to see the source and the driver :)
PostPosted: Tue Aug 23, 2005 13:26
Actually your best solution is not to write directly to the port on a per pixel basis.
Instead use a buffer and create 'setpixel()' and 'getpixel()' function to access your pixel data.
When done 'flush()' the buffer to the lcd. The flush() routine should take care of formatting the data for lcd, which means OR'ing the 8 vertical pixels to obtain the byte.
This is just a general idea of how writting to an lcd could be achieved, but certainly not the best.
Got an email address? The source is 514k without binaries.
PostPosted: Tue Aug 23, 2005 13:53
One more attempt for the sake of it. :)
      if (mode==0) arrayLCD[X+((Y<<7)>>3)] = arrayLCD[X+((Y<<7)>>3)] & (255-(1<<(Y&7)));
      if (mode==1) arrayLCD[X+((Y<<7)>>3)] = arrayLCD[X+((Y<<7)>>3)] | 1<<(Y&7);
      if (mode==2) arrayLCD[X+((Y<<7)>>3)] = arrayLCD[X+((Y<<7)>>3)] ^ 1<<(Y&7);
      SetColumn(X);
      SetStartLine(Y>>3);
      SendLCDData(arrayLCD[X+((Y<<7)>>3)]);
PostPosted: Tue Aug 23, 2005 14:08
      SetColumn(X);
      SetStartLine(Y>>3);
Zee, the 'StartLine' is used to set 'Y' offset in ram and is used to aid a scrolling effect of the LCD, it should be set to 0 at startup then forgotten about.
Replace with SetPage (y/7);
PostPosted: Tue Aug 23, 2005 16:05
My bad...
Maybe I should try to find a KS-based display for my collection. And a way to output data fast for large displays.
PostPosted: Tue Aug 23, 2005 16:35
I'm back!!! No power in the house so I went outside and took freesh air :)
First, THX GUYS, 4 helpin with this crazy plot-pixel-project, THX!!!
Using a buffer with suggested functions seems interresting, I experiment it right away!
This afternoon I was busy with making a clock 4 my LCD, it works now and the time is from system-bios :wink:
My e-mail, see my profile :wink:
Kneego
PostPosted: Tue Aug 23, 2005 16:42
Found out that Y-address increases automatic when u write anything to the LCD.
SetStartLine according the code truly sets the y position but the tricky part is SetColumn-function.
There must be a way to reset the Y-address after writing something so no offsets occur.
PostPosted: Tue Aug 23, 2005 16:55
Zee wrote:
My bad...
One of the methods I use is, and perhaps you're doing this already, is instead of frame transferring the complete frame per update, transfer selective regions, ie (x,y,dx,dy). Ie, if only a block of 5,5 pixels have been modifed there is no reason to flush the complete frame to the LCD. This is easier to implement under user programmability.
Another method which I've yet to implement is to use a backbuffer; this would mean an exact copy of the LCD display output (not its memory configuration) is rendered but which is not directly accessible. It would sit between your framedata (the front buffer) and the LCD. Update the front buffer - flush to the backbuffer (which could be another thread), from there it will determine which LCD pixels actually do require updating, possibly via XOR'ing the two buffers - regions (could be a minimum of 8x8) of difference found and then flushed directly to the hardware.
This allows the software to have multiple frontbuffers (the approach I've taken) with only one backbuffer and in the process completely separating the programmer from the actual design of the hardware (the output device).
Michael
PostPosted: Tue Aug 23, 2005 17:05
SetStartLine does not set the y address per se, if you find that it does then it implies a problem with your code. again, use 'setpage (y mod 8)'
. the remainer of y divided by 8 determines the pixel on the page, setpage (y/8) determines which page to use, then set the x location within that page
PostPosted: Tue Aug 23, 2005 17:24
Want to say thanks 2 Michael 4 the library.
What I need now is time 2 study it :wink:
THX again.
This pixel-function is a thuf nut 2 crack.
Maybe I should re-write and think of drawing frames instead. Drawin frames takes time and fps will be really slow but I only want the Snake-game to work, not really play with it LOL
Thx Michael
Kneego
PostPosted: Tue Aug 23, 2005 18:50
THX again.
Thx Michael
Kneego
No problem, check the 'lRefresh()' functions in ks0108.c for tips on how to update your frame.
Email me the Snake game source and I'll see if I can help, if you like.
PostPosted: Tue Aug 23, 2005 19:00
The way I'm currently using my displays requires pretty much complete update for the whole screen area as there are a lot of changes being made (some results available in the Others-section).
Perhaps when I start implementing some system-level code into my programs but currently I get enough FPS with what I'm doing with the smaller displays.
PostPosted: Tue Aug 23, 2005 19:15
Yes I saw and thought it was pretty neat.
Want to code swap? I'm interested in your drawing routines (the rendering) from the demos.
PostPosted: Tue Aug 23, 2005 20:45
These weren't done by myself but I find them handy sometimes.
Fast linedraw. Works on every angle and without any gaps in the line:
int sgn (long a)
   if (a > 0) return +1;
   else if (a < 0) return -1;
   else return 0;
void Line(int x1, int y1, int x2, int y2, int mode)
   long u,s,v,d1x,d1y,d2x,d2y,m,n;
   int i;
   u = x2-x1;
   v = y2-y1;
   d1x = sgn(u);
   d1y = sgn(v);
   d2x = sgn(u);
   d2y = 0;
   m = abs(u);
   n = abs(v);
   if (m<=n)
      d2x = 0;
      d2y = sgn(v);
      m = abs(v);
      n = abs(u);
   s = (int)(m / 2);
   for (i=0;i<ceil(m);i++)
      Plot(x1,y1,mode);
      s += n;
      if (s >= m)
         s -= m;
         x1 += d1x;
         y1 += d1y;
      else
         x1 += d2x;
         y1 += d2y;
And fast circledraw:
void CirclePoint(long cx,long cy,long x,long y,char mode)
   if (x==0)
      Plot(cx,cy+y,mode);
      Plot(cx,cy-y,mode);
      Plot(cx+y,cy,mode);
      Plot(cx-y,cy,mode);
   else if (x==y)
      Plot(cx+x,cy+y,mode);
      Plot(cx-x,cy+y,mode);
      Plot(cx+x,cy-y,mode);
      Plot(cx-x,cy-y,mode);
   else if (x<y)
      Plot(cx+y,cy+x,mode);
      Plot(cx-y,cy+x,mode);
      Plot(cx+y,cy-x,mode);
      Plot(cx-y,cy-x,mode);
void Circle(long xcenter, long ycenter, long radius, int mode)
   long x=0;
   long y=radius;
   long p=(5-radius*4)/4;
   CirclePoint(xcenter,ycenter,x,y,mode);
   while(x<y)
      x++;
      if (p<0)
         p+=2*x+1;
      else
         y--;p+=2*(x-y)+1;
I'll post some other stuff to the demo-thread.
PostPosted: Tue Aug 23, 2005 20:54
Interesting line draw, quite different from my own:
DLLIMPORT void lDrawLine (TLCD *lcd, int x1, int y1, int x2, int y2, int style)
    int dx = x2-x1;
    int dy = y2-y1;
    if (dx || dy){
        if (abs(dx) >= abs(dy)){
            float y = y1+0.5;
            float dly = (float)dy/(float)dx;
         int xx;
            if (dx > 0){
                for (xx = x1; xx<=x2; xx++){
                    lSetPixel (lcd,xx,(int)y,style);
                    y += dly;
            }else{
                for (xx = x1; xx>=x2; xx--){
                    y -= dly;
        }else{
              float x = x1+0.5;
              float dlx = (float)dx/(float)dy;
              int yy;
            if (dy > 0){
                  for (yy = y1; yy<=y2; yy++){
                      lSetPixel (lcd,(int)x,yy,style);
                      x += dlx;
         }else{
                for (yy = y1; yy >= y2; yy--){
                      x -= dlx;
    } else if (!(dx&dy))
       lSetPixel(lcd,x1,y1,style);
